excursion trouble
Old May 12, 2007 | 11:23 PM
cohusker's Avatar
cohusker
Unhappy excursion trouble
Hi everyone - I'm new to the site and love all the info it provides. I'm also a new excursion ( 03 w/ 6.0L and 67000 miles ) owner and already have a problemafter only puting on 300 miles of my own. I was driving home last night and took a right turn off the highway when it started to sputter lost all of its power and eventually died. I'm not a mechanic by any means but it was trying to start but felt like it wasn't getting any fuel. I had it towed home and woke up and went outside and it fired right up and ran great for 10 min until i shut it off. My fuel gauge still shows just under a 1/4 tank of fuel - anyone had problems with the gauge being misleading? I'ts still under warrenty with the dealer so i will probably take it in next week. I was just curious if this has happened to anyone else or if anyone knows what the problem might be.
THANKS A BUNCH
Old May 12, 2007 | 11:47 PM
Monsta's Avatar
Monsta
Sit. Stay.
Search the 6.0L forum. There is a plunger that gets stuck. Essentially it stops the flow of oil that "runs" the injectors. It's an easy fix (so I hear) with you just needing to pull it out, clean it up a bit and reinstall.
Now this may not be the problem but it is one of the common ailments with a "no-start" situation on a 6.0L.
Again, the search should give you more detail.
Weclome to FTE! Hope you can find your answer here!
Old May 13, 2007 | 10:38 AM
fatswany's Avatar
fatswany
Do 6.0's have the same CPS as 7.3's?
Old May 14, 2007 | 12:33 PM
Bulldog_shotgun's Avatar
Bulldog_shotgun
NO, the cam position sensor is not the problem on the 6.0 it is on the 7.3.
