heater?
Old May 12, 2007 | 10:42 PM
rusty7983's Avatar
rusty7983
heater?
i saw a truck at the salvage yard today. it had the strangest heating system i have ever seen. there was no glove box, instead it had a heater there. it had the blower switch and all. anyone seen one like it? is it original?
Old May 13, 2007 | 12:44 AM
4starcstms's Avatar
4starcstms
Not OE as far as I know... might be a aftermarket setup...
Old May 13, 2007 | 04:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Was there a trim panel on the dash that covered the area where the glove box was? Or was the trim panel missing, which exposed parts of the factory heater through where the panel/glove box was? Was there another glove box attached under the dash, or was that missing too?
What you are describing is Ford dealer installed air conditioning. To use this kit, the glove box and the door were removed, then a new trim panel spanned the dash with registers, the control panel and vents. A "hang on" under dash glove box was installed.
If any or all of these parts were missing, you only saw what remained.
Old May 13, 2007 | 09:41 PM
rusty7983's Avatar
rusty7983
it didn't have the trim panel it was broken. no glove box. no ac compressor. looked like a standard heater setup under the hood.
Old May 13, 2007 | 09:42 PM
rusty7983's Avatar
rusty7983
it was the most unusual heater i've ever seen.
Old May 13, 2007 | 10:27 PM
bucks77ford's Avatar
bucks77ford
You should go back and take a pic of it (if you can). I would like to see that.
Old May 13, 2007 | 10:35 PM
NumberDummy
But it might have had a Ford dealer air, and someone removed all the air specific parts. If the heater looks "weird" it could be the extra cost high output type. Heaters became standard equipment on F100/350's in 1966, so I doubt the heater is anything but a factory set up.
Old May 13, 2007 | 10:38 PM
Mil1ion's Avatar
Mil1ion
People describe things weird ways sometimes
Rusty...did it have control ***** left of the vents and just to the right of the heater controls/radio in the metal area of the dash ?
Old May 14, 2007 | 09:35 PM
rusty7983's Avatar
rusty7983
i didn't look too good at the normal (if it had one)heater control. i was just amazed by it. it had a hot/ cold and blower switch on it.
HRSHAULER
25
Jan 11, 2009 01:46 PM
restoringmy46
Apr 16, 2007 11:58 PM
brider
Jun 20, 2006 02:43 PM
mark-in-wyoming
May 15, 2006 10:07 AM
13hondacr250
Sep 8, 2003 07:20 PM
