1978 - 1996 Big Bronco
Heater problems!!!
Old Dec 18, 2000 | 11:34 PM
chille72's Avatar
chille72
Heater problems!!!
In need of help, I have a 88 bronco 302 with the EEC IV. Now my problem is I am not getting any heat, I have changed the water pump, the thermostat, and the heater core is only a year old. I tried covering the radiator, that heated up the motor but still gave me no heat. I also tried disconnecting the return heater hose and noticed that the coolant flow out of the heater core was only filling the tube about half full if that and no pressure. I don't know if this is normal or not but doesn't look right to me. I would appreciate any suggestions as the temperature is is getting very cold.
Thank's.
Old Dec 18, 2000 | 11:42 PM
jbhf250's Avatar
jbhf250
Heater problems!!!
Is your heater valve opening all the way? Is it vacuum operated?
__JOHN__Õ¿ö
Member-
"Crusin North" Car Club
Santa Rosa, Calif.
72 F-250
ICQ#6030753
Old Dec 19, 2000 | 03:59 PM
chille72's Avatar
chille72
Heater problems!!!
I am not sure were the valve is. Any ideas? As for vacuum I am not sure but I don't think it is.
Old Dec 19, 2000 | 07:45 PM
billyb's Avatar
billyb
Heater problems!!!
maybe with the serpentine belt, the pump rotates the other way and you have the wrong pump! also check the hoses to the core. are they getting warm at all? if so, you are at least getting circulation.
Old Dec 19, 2000 | 10:49 PM
nobody's Avatar
nobody
Heater problems!!!
There should be a valve somewhere in the heater hose that shuts the water off. Check both heater hoses from engine to firewall. With the engine running and the heater set to hot, check and see if the vacuum line is supplying good suction to it, if it is you can get a replacement valve from most any parts store. If there is no vacuum, then start checking the vacuum lines for cracks etc. Sometimes a small vacuum leak is a real headache to find. You could also remove it and use a connector or piece of copper pipe for a temporary fix but next summer when the heater does not shut off, you'll be at the other end of the boat
Alan
_____________________________
95 C350-4x4,PSD,4-Door Bronco(Huh?),49K,auto,AIC,switched glow plugs,switched TC lock-up,4.10,Banks PowerPack,straight piped,Mobile-1 gearboxes,Rotella,BFG AT's 295/75/16
Old Dec 22, 2000 | 03:22 PM
chille72's Avatar
chille72
Heater problems!!!
I would like to thank everyone for their input. I think I have it solved at least for now, I'm not sure exactly what it was. Took the heater core out and filled it partially with CLR and water and then flushed it out really good with water, there was particles of something that did come out of it. Also I noticed that there was a little ice by the temperature control door. I'm not sure if it was one or the other or a combination of both?
I never did find that control valve the only thing I could find is some kind of sensor or switch, one of my core hoses comes out of the core and T,s off to a smaller hose that runs up the intake by were the butterfly's are and back down, and both the heater hose and that one is connected to a tube that stick's up off of the block right behind the thermostat housing and right under were both hoses connect to the tube is the switch or sensor, it has a big black plug with two wires running into the plug and that is connected to this switch or sensor. Anyone have any ideas what this might be?
Thank's again I really appreciate everyone's input.
Old Dec 22, 2000 | 07:52 PM
sharlo's Avatar
sharlo
Heater problems!!!
earlybird 2
20
Mar 6, 2018 05:40 PM
jagger blaze
1997 - 2003 F150
Nov 18, 2014 09:40 PM
tk1251k
Aerostar
13
Nov 29, 2007 01:19 PM
oldmanbergie
1983 - 2012 Ranger & B-Series
16
Feb 12, 2004 04:21 PM
77'F-150Mudder
17
Dec 7, 2003 02:18 AM
