Seperating column from steering box
Old May 12, 2007 | 07:08 PM
hoof's Avatar
hoof
I am having trouble finding room for my steering box. How do I seperate the column and box so I can test fit it?
Thanks,
CHAZ
Old May 12, 2007 | 08:57 PM
55 f350's Avatar
55 f350
can't wait to hear this one , i got two of 'em laying around i've been trying to seperate for a couple of years now . so far the box is winning .
Old May 12, 2007 | 10:03 PM
hoof's Avatar
hoof
Yeah, I posted this elsewhere, and from what I have been told they don't come apart. CHAZ
Old May 12, 2007 | 10:09 PM
55 f350's Avatar
55 f350
does that mean i'm not as stupid as i thought . those darn things are / were driving me nuts ! i got one of 'ems box darn near completely dissambled and it still laughs at me and my futile attempts .
Old May 12, 2007 | 10:35 PM
AXracer's Avatar
AXracer
If you are talking about a stock 48-57 box and column (it really helps if you give these details if you want definitive answers) The only way you can remove the column is with a hacksaw, The gear is part of the column shaft and is not removable.
Old May 12, 2007 | 10:48 PM
stewards68's Avatar
stewards68
If you're talking about just the outer tube, there's just a clamp at the top of the box. You have to disassemble the box, or like AX said, cut it up to get the shaft off the box.
Old May 12, 2007 | 10:53 PM
AXracer's Avatar
AXracer
One more thing, moving the steering box is not a good idea. If you plan on using the stock box, leave it where it was and find your clearance in other ways, i.e. offsetting the engine to the pass side, changing the exhaust manifolds/headers to ones that give the needed clearance.
Old May 13, 2007 | 09:17 PM
55 f350's Avatar
55 f350
well i d0nt know bout him { hoof } but yep thats the ones were talking 'bout . well at least i know now !!!
Old May 13, 2007 | 09:46 PM
reamer's Avatar
reamer
You Have to 1, Remover the steering wheel, (puller required). 2, remove horn assembly. 3. Remove floor gasket, plates. 4,Jack the truck up as high as you can get it. 5, Remove box from Frame. 6, Just getting to this point is fantastic. 7, remove the 4 bolts on box cover. 8, dissasemble inards and the column and "pinion" come out as an assembly.
Old May 13, 2007 | 10:15 PM
theGman's Avatar
theGman
Sounds like a broomstick and tape measure job to me.
Old May 13, 2007 | 11:57 PM
hoof's Avatar
hoof
With my cab channelled 6 inches over the frame I am probably going to have to at least redrill the mounting holes for the box. I have a column out of a '77 Lincoln that I would like to use, I was hoping I could make an adapter to put a rag joint end on the stock box to mate up to the Lincoln column. I think if I remount the motor 1 inch farther forward and use a straight pipe out of the manifold I can make it all fit.
CHAZ
Old May 14, 2007 | 07:35 AM
AXracer's Avatar
AXracer
Hoof, why not eliminate that horse and buggy design steering box and do the Toyota power or manual steering box swap? It's a very easy conversion, especially if you do the power version all the parts are available aftermarket, and does wonders for improving the steering. Mating a different column (or a slightly modified original column) is just a matter of ordering the right U-joint.
reed1951
Ford Truck Parts for Sale
May 23, 2015 04:34 PM
flamesoldier
Feb 11, 2013 10:04 PM
58 ford
17
Jun 17, 2009 05:09 PM
donmodro
May 8, 2009 11:53 AM
52 F3
Nov 30, 2008 09:09 AM
