Sponsored by: Auxito
transfer case fluid
Old May 12, 2007 | 04:07 PM
coral834's Avatar
coral834
transfer case fluid
can anyone tell me where ican finds pics of how to change/check my transfer case fluid?? 2003 f150 sc 30kmiles
Old May 12, 2007 | 04:29 PM
steve(ill)'s Avatar
steve(ill)
lay under the truck, behind the transmission and case by the back drive shaft and look forward. probably has 3/4 inch size plug at the bottom edge to drain, and about a 1/2 inch plug maybe 4-5 inches above it to refill. normally use the transmission fluid used in the truck which would be MERCON V in your case.
Old May 12, 2007 | 04:38 PM
coral834's Avatar
coral834
thanks, i'll check tomarroww
