54 crossmember
Old May 11, 2007 | 09:03 PM
f250red's Avatar
f250red
54 crossmember
I am replacing a 6cyl. with a 292 v8. I need a second front crossmember to support the front motor mount.there is a picture of a section of crossmember in the Joblot catalog with the motor mounts #5057 on the crossmember. Wondered if NumberDummy or someone knew if this is a good number or if this part is available somewhere. if someone has one they will part with,or even an old oneI could duplicate,I have the means to make one if I had the dimentions.
thanks RED
Old May 11, 2007 | 09:26 PM
stewards68's Avatar
stewards68
If I could figure out how to post a pic in a post, I'd put it here. However, the illustration shows #5057 for both 6 cyl. and 8 cyl. If you PM me I'll email you the pic.
