No Heat-89 Bronco
Subscribe
Dec 22, 2000 | 12:03 AM
Reply 0
Dec 31, 2000 | 12:51 PM
No Heat-89 Bronco
We have replaced radiator, thermostat, heater core, and still no heat. Any suggestions? Thanks.
Reply 0
Dec 31, 2000 | 02:34 PM
No Heat-89 Bronco
Sandy,
after it warms up...do the two heater hoses feel hot?
if tehy do, then it could be the heater/air control cable...remove glove box and check the movement..you can remove the cables there; center it and reattach the cable end.
and, if the hoses are not hot; esp the return hose..could be:
blocked inlet hose
water pump
I can't recall if the thermostat can poss. be installed upside down, so...the thermostat is in right?...and engine would not heat up well at all
Reply 0
Jan 6, 2001 | 10:50 PM
No Heat-89 Bronco
My 1994 Bronco (302) has the same problem. If the outside temp is above say 10F then it will eventually get warm. If it is colder than -10F it will never get warm enough to not see your breath. I was suspecting the fresh air vent is not closing enough. I also never have frosted window problems.
But I have no idea where under/behind the dash to look.
John
Reply 0
Jan 7, 2001 | 02:48 PM
No Heat-89 Bronco
for the 94:
"Service Bulletin Number: 93248
Bulletin Sequence Number: 076
Date of Bulletin: 9311
NHTSA Item Number: SB035088
Make: FORD TRUCK
Model: BRONCO
Year: 1994
Component: ENGINE COOLING SYSTEM
Summary: HESITATION-ROUGH IDLE-ENGINE COOLANT DOES NOT REACH NORMAL OPERATING TEMPERATURE MEDIUM TRUCKS WITH 7.0L ENGINES. - HESITATION/STALL DURING ACCELERATION DECELERATION. - IDLE - ROUGH - ENGINE COOLANT DOES NOT REACH NORMAL OPERATING TEMPERATURE. - HEATER/DEFROSTER - POOR HEATER OUTPUT - THERMOSTAT STUCK OPEN. COOLING SYSTEM - NEW DIAGNOSTICS FOR ENGINES THAT DO NOT REACH NORMAL OPERATING TEMPERATURE. (FORD TBS 93-24) *TW "
source: http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy.cfm
and:Service Bulletin Number: 942016
Bulletin Sequence Number: 070
Date of Bulletin: 9410
NHTSA Item Number: SB037464
Make: FORD TRUCK
Model: BRONCO
Year: 1994
Component: HEATER:UNKNOWN TYPEEFROSTEREFOGGER
Summary: HEATER - LOW/NO HEAT WHEN TEMPERATURE **** IS SET AT FULL HEAT. *TW
and:Service Bulletin Number: 96 137
Bulletin Sequence Number: 21
Date of Bulletin: 9606
NHTSA Item Number: SB048450
Make: FORD TRUCK
Model: BRONCO
Year: 1994
Component: HEATER:UNKNOWN TYPEEFROSTEREFOGGER:CONTROL SWITCH
Summary: LOW OR NO HEAT/AIR CONDITIONING-HIGH EFFORT TO TURN TEMP CONTROL ****
Reply 0
Subscribe
