Gear Ratio Calculation
Old May 11, 2007 | 01:07 PM
Jag Red 54's Avatar
Jag Red 54
OK, I think I'm doing it right, but I need somebody to check my math. We checked the rotations on two rearends. With the left tire jacked off the ground I counted tire revolutions vs drive shaft revolutions:
10 tire revolutions with 19.5 drive shaft revolutions = 3.90 gears???
19.5 / 10 = 1.95 x 2 = 3.90
and
10 tire revolutions with 16.5 drive shaft revolutions = 3.30 gears???
16.5 / 10 = 1.65 x 2 = 3.30
Is this correct or am I all goofed up? Thanks, Jag
Old May 11, 2007 | 01:37 PM
stewards68's Avatar
stewards68
Think you're right. I always thought of it by going around twice as many times with the tire which would be the equivalent of both wheels going around once. So if you went 10 times around, you'd divide by 5 instead of 10. The same as multiplying your answer by two.
Bottom line, despite goofy explanation, I think you're right.
Old May 11, 2007 | 06:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Looks right!
Old May 11, 2007 | 07:27 PM
imlowr2's Avatar
imlowr2
Jag, not sure why you do the 10 revolutions? I usually raise the rear end off the ground. Make one complete revolution with the wheel tire and count the revolutions of the drive shaft (I usually mark the U joint) If the drive shaft turns 3 complete with the one revolution of the tire, that's 3.00. If the drive shaft is less than 3, say 2 3/4, you probably have 2.70 or so. Slightly more than 4 turns, 4.11. This method has given me a very close idea of what my gearing is if not exact. Best way and accurate way is to count the ring pinion and divide the numbers such as 45 teeth on the ring and 13 on the pinion. 45 divided by 13= 3.46 or 3.50 gears. Hope this helps.
Old May 11, 2007 | 09:15 PM
stewards68's Avatar
stewards68
By the way...looking back at my other post, I meant to imply MY explanation was goofy, not yours! That didn't sound very good when I reread it...!
Old May 11, 2007 | 09:27 PM
WillyB's Avatar
WillyB
This works with open rear ends - it is different with traction lock rears.
But I agree with your math.
Old May 14, 2007 | 10:06 AM
Jag Red 54's Avatar
Jag Red 54
Thanks for the input everybody. Now, all I have to do is find some new 3.30 gears. Do they still make gears for the old mid-fifties Dana/Spicer? Jag
Old May 14, 2007 | 11:23 AM
imlowr2's Avatar
imlowr2
They should Jag, there's two guys I use for rear ends, both excellent references.
Ramjet Rear Ends, 9075 Glenoaks, Blvd, Sun Valley, CA. 818-768-7786
Hooper's Rear end exchange, 12201 Branford st. Sun Valley, CA 818-899-2515
These guys both know their stuff. If you contact Ramjet, ask for Don (owner) or Eddie( head guy)
Old May 14, 2007 | 11:48 AM
Jag Red 54's Avatar
Jag Red 54
Thanks Ed, I'll check it out. John
