Where does this go???
Old May 10, 2007 | 07:28 PM
b2trausch's Avatar
b2trausch
Please help. I'm changing the AT filter in my daughters 2000 MM (5.0) with AWD. When I removed the filter from the bottom of the transmission, a piece that looks like a top, cream in color, with an o-ring around the larger end fell out. I understand that there are a couple of different types of filters used on these trucks. Mine is the type that is kidney shaped, and has an angled pick-up tube on the bottom.
I have no idea where it came out from, but I suspect that it goes in the top of the filter tube. But if it does go in there, I don't know which end goes up.
I've never done any transmission work on this truck before, so I don't have a manual for it. Any help, or diagram that shows how this goes together would be greatly appreciated.
Old May 10, 2007 | 09:06 PM
911bear's Avatar
911bear
my "GUESSTAMENT ONLY IS" that would be the factory "Plug" in the hole where the dipstick tube goes in, i believe that the assembly workers just push the tube in and the plug falls into the transmission pan , it causes no known problems that i know of.. "BUT ONLY A GUESSTAMENT"
Old May 10, 2007 | 09:31 PM
caseys's Avatar
caseys
It is a piece that ends up in the tranny pan at the factory. Do a search on this forum (in the transmission section) and you will find a bunch of comments on this...nothing to worry about, just toss it.
Old May 10, 2007 | 09:40 PM
b2trausch's Avatar
b2trausch
Thanks a bunch for the info. I guess that this is a good indicator that the transmission hasn't ever been serviced. The truck has 125,000 miles on it so this doesn't make me very happy.
The fluid was not horribly discolored, and didn't smell abnormal at all so I'm hoping that the transmission will live a while longer. I guess it's a good thing that I had already planned on doing a 100% fluid flush.
Thanx again.
B2
Old May 11, 2007 | 12:43 AM
edgl's Avatar
edgl
You can figure that the trans has not been serviced, if that factory plug was still in the pan. No body puts them back in.
Old May 14, 2007 | 10:40 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Just because the pan hasn't been dropped doesn't mean the transmission hasn't been serviced.. it may have been flushed.
Yeah 125k on the filter may be a bit much.. .but that doesn't mean the fluid hasn't been changed.
