1978 - 1996 Big Bronco
TRANNY PROBLEMS
Old Jan 20, 2001 | 11:31 PM
big80bronco's Avatar
big80bronco
TRANNY PROBLEMS
I HAVE A 1980 BRONCO 351M WITH A C6 AUTO TRANNY. I COMPLETELY REDID MOTOR AND WHEN I PUT THE MOTOR BACK IN THE TRANNY STARTED SLIPPIN REAL BAD, I HAD TO GO THROUGH GEARS 1,2,D TO KEEP HALFWAY UP TO SPEED. FINALLY MY FORWARD GEARS WENT OUT AND NOW I ONLY HAVE REVERSE. I KNOW THE CASE MOST LIKELY IS THAT MY CLUTCHES BURNED OUT BUT HAVE HEARD THAT TRANNY IS SPECIAL TYPE C6 AND WOULD LIKE TO KNOW MORE ABOUT IT. PLEASE HELP!!!
Old Jan 21, 2001 | 07:07 AM
Bob_VT's Avatar
Bob_VT
TRANNY PROBLEMS
You have a "big block" C-6. (and a dead one by the sound of it) If you visit a junk yard only a C-6 from the big blocks will fit. You will need one with the large spacing on the bell housing bolts. A tranny from a 351m / 400 / 460 will fit good luck.
Old Jan 21, 2001 | 11:14 AM
big80bronco
TRANNY PROBLEMS
THANX FOR YOUR HELP. WILL ANY C6 BIG BLOCK TRANNY OUT OF A TRUCK DO? OR DOES IT HAVE TO BE OUT OF A 4X4? IVE HEARD THAT A BRONCO C6 IS EXTREMELY SHORTER THAN MOST C6 TRANNYS
Old Jan 23, 2001 | 07:25 PM
Bob_VT's Avatar
Bob_VT
TRANNY PROBLEMS
Well any of the big block C-6 tranny's will work however..... converting the tailshaft will require some serious work and I would suggest an experienced transmission mechanic do it. Kepp hunting for a 4x4 tranmission for a big block, they are out there or..... bite the bullet and have your rebuilt.
Old Jan 23, 2001 | 09:21 PM
big80bronco
TRANNY PROBLEMS
