MSD ignition
Old May 10, 2007 | 02:29 PM
semperfiob's Avatar
semperfiob
MSD ignition
I have a 74' F100 4x4 360 CI with a MSD ignition. The problem i'm having is the Wires are starting to melt were they rest against the engine. Is there straight wires with out the 90 degree bend in it.
Old May 10, 2007 | 03:50 PM
Alvin in AZ's Avatar
Alvin in AZ
Of course. :)
I just got some Bosch wire-wrapped type from AutoZone.
I cut the ends off the distributor end an re-connect them when I shorten the wires.
I set mine up so none of the 'wires" touch grounded metal.
YMMV
Alvin in AZ (75 360FE Blue Streak ignition module and coil)
Old May 11, 2007 | 03:01 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
We can build our Live Wires to specific lengths and specific boot angles for each cylinder for you.
http://www.performancedistributors.com/livewire.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
