1978 - 1996 Big Bronco
High Flow cats for OBD-II
Old 01-08-2001, 10:07 AM
mafman's Avatar
mafman
mafman is offline
Hey Folks,
Anybody know of a high flow cat setup for the 1996 351 OBD-II Bronco? It's got the dual cat setup and I'm afraid to touch the damn things.
1996 351 Auto
Old 01-23-2001, 12:58 PM
mafman's Avatar
mafman
mafman is offline
ttt
Old 01-23-2001, 01:24 PM
zeindog's Avatar
zeindog
zeindog is offline
I too have a 96 bronco w/ a 351, I replaced my cats with a bassani y-pipe with a new cat in it and I have had no problems since with the computer.
Old 01-23-2001, 08:12 PM
oldblue18's Avatar
oldblue18
oldblue18 is offline
I have a 95 bronco with a 5.8 and do not have to pass emissions. Will it screw up the computer if i removed the cats all together?
I realize that this will give me more power and gas milege, if it does not affect the computer. I just realized how much i DESPISE computer controlled engines. Give me a carb any day.
Old 01-24-2001, 08:15 AM
mafman's Avatar
mafman
mafman is offline
I wouldn't do that simply due to the reduced backpressure. Your computer expects a certain amount of backpressure to go along with the parameters set up in the PCM. If those parameters aren't met, you definitely won't get more power or improved gas mileage from the setup unless you get a custom chip. Even then, I can't see where a 200HP engine would benefit from anything beyond a 2 chamber cat back system, maybe some headers. Especially if you don't have MAF up front...the computer has no way to compare air coming in to the extra air leaving.
Just my .02.
Old 01-24-2001, 04:11 PM
oldblue18's Avatar
oldblue18
AS for power...it used to be(in the 1970's) that if you out true duals on a car and took off the cats, you could get 15% more hp. I have 215hp now, so this would give me about 32 more hp plus around 5-7 more mpg. This is a lot of power for that ammount of $$$
Old 01-24-2001, 04:21 PM
mafman's Avatar
mafman
mafman is offline
The good old days....
There are things you can still do. Bump the base timing up a bit, if you don't live in a cold climate bypass the coolant from the throttle body, a cat back system has netted me a few extra HP along with a K&N filter. Some shorty headers with O2 flanges would be nice, provided they're coated (you wouldn't want your engine to get unusually hot and trick the computer into backing off the timing).
Bla bla bla. Good luck.
Old 01-24-2001, 09:47 PM
tuffguy's Avatar
tuffguy
tuffguy is offline
Gary Lewis
2015 - 2020 F150
06-27-2015 11:48 AM
linckeil
24
02-04-2015 11:22 AM
msaylor
10-02-2013 11:58 AM
Fordman96
Computer Chips & Tuners
06-06-2013 06:19 PM
1997-2006 Expedition & Navigator
08-23-2002 03:30 PM
Quick Reply: High Flow cats for OBD-II
