Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
428 Police interceptor engine
Old May 11, 2007 | 10:29 PM
preppypyro's Avatar
preppypyro
Yeah I think numbers is the only way too. Is the engine just loose? Or is it still in the vehicle?
Old May 12, 2007 | 12:22 AM
LaredoF350's Avatar
LaredoF350
The engine is loose and the guy told a friend of mine that he took it out of an old cop car. We will be looking at it in about a week. Even if its not an interceptor, the price is fair and I will probably pick it up anyways.
Morris, Rob did some internet digging and got me a whack of block, head, and intake casting numbers. Once i get it I might get your books and who knows, with some persuasion, might get your expertise out to the farm to look her over.
Old May 12, 2007 | 11:55 PM
LaredoF350's Avatar
LaredoF350
We did quite a bit of homework. It sounds like that thing made some good power - Ford rated hp @ 345-360 and torque around 460. Some articles said hp closer to 400. They rated the CJ and SCJ at 335 hp and 440 ft lbs.
One interesting tidbit - the aluminum intake shaves 55 pounds off the engine vs the cast one and is identical to the CJ as far as flow is concerned.
Old May 13, 2007 | 12:07 AM
Fomoko1's Avatar
Fomoko1
Ford under rated these engines to gain an advantage in the factory stock classes..
One good thing I hung on to all these years was a 68 Shelby aluminum manifold that`s on my 67 Fastback saving me those 55 lbs....
Old May 13, 2007 | 12:10 AM
LaredoF350's Avatar
LaredoF350
Those FE engines are pretty heavy. The 428 numbers I saw were 610 for cast intake and 550 or 560 for aluminum. Any idea where a 351 would come in for weight (not sure whats all included when they did those weigh ins)?
Old May 13, 2007 | 12:17 AM
Fomoko1's Avatar
Fomoko1
Aluminum heads are avialable for the FE series but I have no idea of the cost. The 429 aluminum heads are around $2,000 a set I believe.
An all alluminum FE 427 was/is avialable from Shelby, don`t ask the price.....
Old May 13, 2007 | 10:33 AM
96sherm's Avatar
96sherm
aluminum sure does raise the cost quite a bit!! as do carbon fibre!!
Old May 13, 2007 | 09:11 PM
preppypyro's Avatar
preppypyro
Sounds like those motors were really powerfull. Will definatly make a mustang fly. You might have to go for your pilots licence if you buy this motor!
Old May 13, 2007 | 10:28 PM
Dustin1690's Avatar
Dustin1690
Oh yeah they sure are powerful probably 2000 for heads yikes
Old May 13, 2007 | 10:30 PM
preppypyro's Avatar
preppypyro
Yeah not cheap but think of how cool they would be to have!
Old May 14, 2007 | 12:01 AM
Fomoko1's Avatar
Fomoko1
From mid 1968 thru 1970+ the 428 CJ Mustangs owed most drag strip records in it`s classes.
We were lucky enough to have a 428 67 Fairlane racing at SIR thouygh I had to work Sundays and never got to see it. One day it rolled while out on the track and was gone forever....
Old May 14, 2007 | 01:02 AM
FirstTry's Avatar
FirstTry
a way to get a rough ideo is to take a spark plug out and stick a dowl inside and get a rough idea of the stroke. not perfect, but fairly accurate, as some block numbers on FE's were repeated i believe. if it is an aluminum intake, and it looks like an original intake, that points to it being diffrent than a regular FE.
428PI were used in 68 Shelby's
Old May 14, 2007 | 10:34 AM
  #28
preppypyro's Avatar
preppypyro
I wonder how a 428 CJ, would do against a 426 hemi.. That would be sweet.
Old May 14, 2007 | 09:37 PM
  #29
Dustin1690's Avatar
Dustin1690
Yeah no kidding eh preppy
Old May 15, 2007 | 10:39 AM
  #30
preppypyro's Avatar
preppypyro
So laredo, did you manage to go pick er up??
