360 information
Old May 9, 2007 | 01:00 PM
Titantis's Avatar
Titantis
Question 360 information
So there is a chance that I may be getting a 360 out of a 1974 F-250 I think it is. Its free if I buy the bed from the truck, and the bed is 100 bucks, so I'm pretty sure I'm gonna go ahead and pick it up. I was wondering if parts from all the other FE engines would interchange with it, and how they are on performance. From what I have read they are pretty low compression engines are they not? Is this because they have large combustion chamber heads, or do they have dished pistons? Both? Any and all information will be greatly appreciated!
Old May 9, 2007 | 06:17 PM
704core's Avatar
704core
Not much help...
Hey Titantis, I'm not very knowledgeable on the subject as I am a VW transplant. But from what I understand, the 360 & 390 FE motors are the same except for the crank, rod, and pistons. There is just a lil longer stroke on the 390. The Haynes manual shows a 3.50 stroke on the 360 and a 3.78 stroke on the 390. Both have a 4.05 bore. As far as the compression issue goes I'm not sure since I'm new to the whole V6 & V8 scene. Sorry I wasn't more help but I saw that no one else had posted a reply yet and just thought I'd try and help how I could. Laters
Old May 10, 2007 | 12:29 AM
Alvin in AZ's Avatar
Alvin in AZ
Yeah you have to work at it to get the compression up and the 360's came with a 2 barrel carburetor so it -can- be a dog. One way to "spot" a 390 is if it's got a 4 barrel intake manifold. Of course you still don't know what you've got until you measure the stroke tho.
There's things that can be done to wake them 360's up.
Just a while back there was a whole thread on just that. :)
705 are you a ramva transplant by any chance? :)
I've never rebuilt a V8 only VW and motorcycle engines.
I'm on the look out for a 390 with a 2 barrel intake manifold. :)
I like dogs. ;)
Alvin in AZ (F150 2wd 360FE T18)
Old May 13, 2007 | 03:53 PM
Titantis's Avatar
Titantis
Sweet, so what transmissions fit the FE engines?
Old May 13, 2007 | 04:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F100/350's.
Automatics: Ford used: C-4's on some in 1965-66's; MX Cruise-O-Matics in 1965-67; and C-6's 1968 thru 1976.
Standard shift: 3.03 fully syncro 3 speeds. T-85N overdrives 1965-72, 4 speed New Process 435's, Warner T-18's and T-19 4 speeds.
Old May 16, 2007 | 10:41 AM
henry1976's Avatar
henry1976
I have a 360 in a 76 f150 2wd. I bored it .040 a few years back, put on flowmaster dumped duals, and holley/wieand intake, edelbrock 600, and an rv cam ( one step up). It certainly has more power but I have two questions:
1. is there a better carb set up for this truck than what I currently have on it?
2. what can I do to wake it up even more without spending a ton of money.
I have a four speed granny gear tranny in it. Should I consider looking for a different tranny? I love the granny gear but it is not exactly condisive to speed.
Old May 16, 2007 | 10:43 AM
henry1976's Avatar
henry1976
i realize that I hijacked this thread. I had the questions popping into my head as I was reading the previous posts. So, sorry.
steve33444
106
Nov 30, 2020 10:37 AM
Vickadelphia
17
Dec 13, 2013 08:24 PM
76HighboyGuy
WTB - Parts & other
Aug 8, 2011 08:13 PM
mktsc
Dec 16, 2010 04:11 PM
77FordDW
Engine Swaps
Nov 11, 2008 07:25 PM
