6 Volt battery
Old May 9, 2007 | 09:55 AM
john fin's Avatar
john fin
6 Volt battery
Does anyone know where I can find a 6-volt car battery?
Old May 9, 2007 | 10:09 AM
54 gene's Avatar
54 gene
Go to any Auto store.
Old May 9, 2007 | 10:24 AM
john fin's Avatar
john fin
The parts houses in my area dont carry them. Napa can order one but they are $85.
Old May 9, 2007 | 10:27 AM
MO51's Avatar
MO51
6volt battery
In my town (Sacramento), the chain auto supply stores don't stock them, but the larger "battery supply" places do. Lots of old farm tractors still use 6volts, as of course do old cars. My last one was $56, two weeks ago.
Old May 9, 2007 | 10:33 AM
dennisb56's Avatar
dennisb56
I got mine at Tractor Supply company, it might be a little smaller but it works for me. I think it was about $35. I also found them at PepBoys on the shelf for around $70. I am undecided yet on converting to 12 volt so the cheap 6 volt was good enough to get me running for now.
Old May 9, 2007 | 12:16 PM
john fin's Avatar
john fin
I am starting to think about converting to 12volt after seeing what battery prices and availability are. The pros would be that I could get a cheap battery, use my battery charger if required, cheaper and available elec. parts, ie coil and such. I guess the starter and generator would be the cons for converting. Any thoughts or ideas?
Old May 9, 2007 | 01:29 PM
Jag Red 54's Avatar
Jag Red 54
If your wiring is in good shape, keep the 6-volt. It's cool and retro. I bought my last 6v battery in 2006 at a place called the battery shop. The Batteries Plus store also carries them. I think they were about $45. Even Kragen carries them in the back room. Good luck, Jag
Old May 9, 2007 | 01:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FYI: 1948/55 6 volt batteries can be either group 2L or 2N. The 2N's (originally) had more cranking amps.
Old May 9, 2007 | 08:51 PM
jeffh's Avatar
jeffh
I bought my last battery at CarQuest. They didn't have it in stock, but received it from the warehouse the next day.
Old May 9, 2007 | 11:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
John -- I see you're new here -- Welcome! We prefer that posters give us some basic information like what year truck they're talking about, whether it's stock or not, etc. It would also help to know where you are so we can suggest places near you.
Converting to 12v is a frequent topic here, and if you search on "12v" you'll find many many threads on the subject. You don't need to change your starter, but there are alternatives for dealing with gauges and alternator or generator. Wiring changes are also needed. I made the switch to 12v because of constant problems with the 6v system. I have not regretted it for a minute! Expect to spend about $200 all said and done, at a minimum.
Old May 10, 2007 | 07:19 AM
john fin's Avatar
john fin
What constant problems were you having with your 6volt system? I live in central Florida.
Old May 10, 2007 | 08:39 AM
ALBUQ F-1's Avatar
ALBUQ F-1
My system voltage was all over the place; couldn't pin it down to either the gen or the reg, both seemed to be set correctly. Naturally the battery didn't last long under those conditions, and even tho I had no trouble finding a 6v battery (stocked @ AutoZone) they cost as much as a really good 12v battery. Couldn't run any modern accessories, trouble finding 6v bulbs, yadda yadda yadda....
Old May 10, 2007 | 08:55 AM
john fin's Avatar
john fin
Do you still have your 6volt generator and regulator. I am in need of those parts.
Old May 10, 2007 | 09:37 AM
Jag Red 54's Avatar
Jag Red 54
John, A new regulator at NAPA runs about $20. Get one that is not riveted together. Some brands have screws that hold the cover on. These units can be adjusted. What year is your truck? Is it stock? Do you have a repair manual for it? Is it possible the problem is that you have not polarized your generator? The manual tells you how to do that and the setting of the three contacts in the voltage regulator. How much voltage are you seeing when the truck is running? 7.2v is about right. Please tell us the simptoms of your problem. Jag
Old May 10, 2007 | 10:11 AM
john fin's Avatar
john fin
Well, easy, the main problem is it's missing a generator and regulator. Truck, 49' is original and I am at the point were I need to decide whether to go 12v or 6v. I love original things and usually never stray from that BUT, I also like to pay for parts at a resonable price. I would think that if I went with a 12v system, I could get more bang for the buck, ie CCA's, and still keep the original battery size( we can thank import cars for that one). I good thing that was mentioned was the difficulty getting 6v bulbs. p.s. do you have that p/n for the 6v regulator at napa and it is solid state or relay type?
