Sponsored by: Auxito
Rear Door Locks
Old May 9, 2007 | 08:53 AM
jrm05261966's Avatar
jrm05261966
Rear Door Locks
need some info ????? I have a 97' explorer and both back doors will not open from the inside. plastic handles a fine , one is new. they both open fine from the outside handle. is there a way to by pass or check the child proof lock override?? when you pull the inside handle to open it feels like it almost opens the door , but not qiute. need some help
Old May 9, 2007 | 05:16 PM
steve(ill)'s Avatar
steve(ill)
on my 1996 there is a black "switch" in the door jam area under the door handle. ypu push it up or dwon to engage or disengage the child proof stuff. mine was stuck. soaked with WD40 and then moved it up and down a couple times and now it is off.
Old May 9, 2007 | 09:52 PM
bla1879's Avatar
bla1879
same thing happened in my 2000 expy, it got stuck and wouldnt quite unlock the child lock, i did the same as steve(ill) soakes with wd40 move its bout 10 times and it stayed from there on out wherever you put it
Old May 10, 2007 | 06:45 AM
jrm05261966
will try this , tx allot
Old May 23, 2007 | 01:47 PM
jrm05261966
did not help , can these be bypassed or removed ??
Old May 23, 2007 | 02:26 PM
73f350sc's Avatar
73f350sc
I have a feeling that you may get more help if you posted in the correct fourm seeing as this isnt the Explorer forum...its F150....also its possible that the linkage inside the door has broken....you may have to remove the door panel to repair or replace it.
-Chris
Not being mean....just tryin to help ya get the best answer
