02 Explorer 4.0
Old May 7, 2007 | 06:07 PM
426's Avatar
426
02 Explorer 4.0
Well I have a new one. I can't get gasoline in my Explorer. I get to the pump, put in the nozzle and it keeps clicking off. This has happened at different stations. The only thing I can do is squeeze the trigger very slowly, to let the fuel trickle in. Anyone have any ideas? Your help is appreciated.
Old May 7, 2007 | 09:07 PM
aagitch's Avatar
aagitch
sounds like something is obstructing it between the tank and where the cap is. maybe you had a prankster stuff something in there.
Old May 8, 2007 | 05:06 PM
steve(ill)'s Avatar
steve(ill)
as the gas goes down the tube, the air needs to get back out of the tank. there is a 1/2 inch line off the gas tank with a rubber hose that vents to the top of the fill line somewhere. it could also be plugged or collapsed.
Old May 9, 2007 | 12:02 PM
426's Avatar
426
Thanks to everyone. I checked the throat but found it clear. So, I'll go hunting for the vent tube.
Old May 9, 2007 | 07:19 PM
redwing76's Avatar
redwing76
Shove the nozzel farther in.
You live in the PRC? I do and sometimes you have to hold the "donkey dick" nozzle back by hand to get it run. Its a feel good PRC thing.
