'95 f150 scan code 172 question
Old May 7, 2007 | 05:56 PM
12secondstang's Avatar
12secondstang
I just purchased a 95 F150 XLT 5.0 Auto. I ran the engine codes and got two. Code 73 and 172. I changed the TPS. While at it I changed the wires and Coil as there was a misfire at the coil wire. I disconnected the battery then drove truck. Now it runs great but still have code 172, the O2 senser(lean).
Question, Can i just change out the O2 senser or could there be(other than the TPS) another reason it tripped.
Old May 7, 2007 | 06:54 PM
dagray3's Avatar
dagray3
some people have sort of said that the EGR might be letting too much exhaust into the system, making it run lean. Some people have put in an EGR restrictor plate to change the volume of air going into the EGR.
But, if you have a haynes or chilton's manual, I think they tell how to check the O2 sensor to make sure it's accurate, and not bad. It probably requires a voltmeter to check.
So, follow the manual procedure to check the o2 sensor first. I don't know how much they cost on our trucks, but I have seen some pretty expensive ones for other cars.
Old May 7, 2007 | 09:31 PM
12secondstang
Thanks, I already have the O2 sensor. I can't the old one out yet. I am going to need heat for this one.
Thanks for the input.
Old May 8, 2007 | 01:40 PM
dagray3's Avatar
dagray3
my hyanes manual says to warm the engine for a few minutes to get the o2 sensor out.
AMDFX8150
Feb 26, 2016 11:41 AM
smilespergallon
Aug 2, 2015 10:34 AM
rcgtsport
Escape & Escape Hybrid
Feb 20, 2014 07:54 PM
bbens
New Member Introductions
Aug 6, 2006 07:33 AM
beth
Jan 28, 2004 08:11 AM
