Water Pump/Thermostat Compatability
Old May 7, 2007 | 04:25 PM
dustinova's Avatar
dustinova
I've read from various posts that the thermostat to get when replacing one on a 335 engine is a Robertshaw 333 series that can be purchased from flowkooler. I checked out their website, and emailed them asking about using this t-stat with a stock replacement water pump, and the reply I got made it sound like the only time one of these t-stats needs to be used is when using one of their $100 water pumps with it. Is this the case, or are you guys running these thermostats with the stock water pumps?
Old May 7, 2007 | 06:51 PM
unrulee's Avatar
unrulee
I don't think that you have to run THEIR water pump, that doesn't make any sense. I've been on this forum for quite a while and have heard about the robertshaw thermo's alot. Nothing that I've ever heard said anything about having to run an aftermarket water pump. I belive that it's the stock equivalent t-stat.
Nice truck by the way!!!!
Old May 7, 2007 | 07:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
That is the good stock equivalent stat. Works fine with the stock pump. Sounds like some con-artist salesman was trying to drain your wallet.
http://www.cooperstandard.com/us/en/...Thermostat.asp
tbear853
Nov 27, 2016 11:05 AM
Chiver
1983 - 2012 Ranger & B-Series
Jun 6, 2015 04:33 PM
strokin'_tatsch
Nov 29, 2011 02:40 AM
PHOTOG101
Sep 30, 2009 05:21 PM
Ed Trethewey
Apr 18, 2004 07:24 PM
