Wheel coating
Old May 7, 2007 | 04:04 PM
Hawk180's Avatar
Hawk180
Wheel coating
Does anyone know of a solvent that will remove the clear coating on the Ford alloy wheels? My front ones are chipped, so I would like to remove the coating, clean them up and put a coat of Glisten on them.
Old May 7, 2007 | 06:16 PM
lostin90s's Avatar
lostin90s
I just use a citrus base paint shipper . And clean with 3M pads . I have got them reclear coated . But now I just polish them when I wax the truck Good luck
Old May 7, 2007 | 07:00 PM
mrl390's Avatar
mrl390
Try some basic lacquer thinner. I would be cautious with using stripper on aluminum, but thats just me. Id scuff up the clear coat a little then soak a rag and rub on some thinner on until all the clear is gone.
Old May 7, 2007 | 07:25 PM
mhg's Avatar
mhg
sand blasting works
just be careful to not get carried away
you can etch the surface
this is not a bad thing but wont look polished
