I don't know jack...
Old Feb 27, 2012 | 03:22 PM
crazy96863's Avatar
crazy96863
Is a 2 ton jack enough for these trucks? I know my truck weighs something like 4500 lbs but I will not be lifting the whole thing all at once.
Same thing with the stands... Is it 2 tons per or combined?
Thanks!
Old Feb 27, 2012 | 03:32 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Should be ok. I've used it before with no problem.
Old Feb 27, 2012 | 04:25 PM
ChaseTruck754's Avatar
ChaseTruck754
should be ok. I lift my '74 F-250 crew cab 4wd with a cummins in it with a ton & a 1/4 jack...
Old Feb 27, 2012 | 06:54 PM
TexasTrash's Avatar
TexasTrash
You'll probable be fine with the lifting capacity. However if you ever think you will need to have the whole front end up off the ground for any reason they probably wont go tall enough. I just ran into this problem last week when i replaced my radius arm bushings. Had to get the 6 ton ones to get the truck off the ground with the stands under the frame. Oh and the stands are 2 ton per stand.
Old Feb 27, 2012 | 07:18 PM
crazy96863's Avatar
crazy96863
I am really just looking to put jack stands under the axle. By jacking on the axle and perhaps with a block of wood or something I think the lift will be enough. If I had to go higher I have a lift stall I can rent but that is only for one day at a time where I am gonna have it up on stands for a few weeks.
Damn jacks get expensive so especially with the higher lift capacities. I found an ok 2 ton set (jack & stands) at Oreillys for $50 I think I am gonna get. Seems slightly better than the harbor freight / walmart sets and a little cheaper to.
Old Feb 27, 2012 | 07:29 PM
TexasTrash's Avatar
TexasTrash
Yeah you'll be fine.
Old Feb 27, 2012 | 07:32 PM
crazy96863's Avatar
crazy96863
Thanks! Just didn't want to go so cheap that someone (namely myself or my truck) gets hurt.
Old Feb 27, 2012 | 07:55 PM
devino246's Avatar
devino246
I bought a set of high lift stands at sears. I can't remember how much I payed but I think it was somewhere around $30.
EDIT: Here they are: Sears: Online department store featuring appliances, tools, fitness equipment and more
Old Feb 27, 2012 | 08:31 PM
cumminsdude95's Avatar
cumminsdude95
I use a 48" 3 1/2 ton farm jack and 2 ton jack stands only because of my lift and tires. I also found my stands at a flea market for $10 in good condition so look there first before buying new.
Old Feb 27, 2012 | 08:34 PM
crazy96863's Avatar
crazy96863
Was thinking about that or yard sales... Craigslist has been anti jack for some reason. I will be a few days before I really need it so will keep my eyes open.
Old Feb 27, 2012 | 08:40 PM
cumminsdude95
Yea if you don't mind looking through a lot of crap sometimes you find good things really cheap.
Old Feb 27, 2012 | 09:09 PM
2506deer's Avatar
2506deer
jack
blew out my GOODWRENCH (chevy) jack .. go figure..... lifting the front of my 77 4X4 F150 so go big
Old Mar 3, 2012 | 12:07 AM
crazy96863's Avatar
crazy96863
I broke down and bought the 3 ton set at harbor freight for $100.
Old Mar 5, 2012 | 10:18 PM
2506deer's Avatar
2506deer
good choice
Yeah I think that was the way to go after blowing out the seal in my 2 ton jack I should do the same
Old Mar 5, 2012 | 11:15 PM
crazy96863's Avatar
crazy96863
If you go harbor freight keep an eye open for coupons... I found one in petersons offroad and saved $20 on the jack... Been having better experience with their stuff to so probably gonna go there more.
Side note- i read both manuals (imagine that) and it stated that stands are rated by the pair unless otherwise stated. 2 ton stands would work but they are literally within a few bucks so might as well go big. These were $20; cheaper than 2 tons elsewhere.
