4.6L Hesitation Under Load when HOT...
I have a 4.6L that runs great when cold. After warming up you gradually feel hesitation when accelerating. Continue to drive and the problem gets worse, especially on inclines when the engine comes under load. Bad fuel is ruled out as this has been going on for months. Engine Service Light has not come back on since I change all EGR components. I would think it is an injector issue or a COP, but why does the ruff running only occur after the engine gets hot?
The Truck had been running bad for sometime. Eventually the Service Engine Light came on. I went to the Auto Zone free diagnostic and it showed an EGR issues. I replaced the EGR Valve and it did not fix the problem. Light was reset and came back on as problem continued. I cleaned the old valve and tube (not dirty at all) reinstalled and returned the new valve. I purchased and installed an EGR regulator. Seemed to fix the problem. Had the Engine Service Light reset (and it has not come back on to date). Truck ran good for about 100 miles. Then the problem resurfaced. The parts store allowed me to replace the new EGR Regulator - still had problem. Replaced the DPEE - still had problem. I have not check current going to these components yet. No apparent vacuum leaks….
It could be something as simple as your battery terminals. Before you change plugs or something else check out your battery terminals, a loose or corroded connection will cause hesitation, loss of power travelling up inclines. This happened to me this spring on my 97 5.4 expy, no engine light came on either.
waboose:
I did not even suspect a bad battery connection as a culprit. I did coincidentally clean the terminals and connectors a few weeks ago just because I was working under the hood – no change in poor performance.
I have a twenty mile drive to work, mostly interstate / highway with one large bridge. The vehicle hesitates a little on the way to work going over the bridge and has extreme hesitation on the bridge heading home. The weather here today 100% humidity/rain and the hesitation is barely noticeable. It almost seems like the problem is worse on hot/dry days. Sounds crazy but it’s the truth …
If someone else didn't already mention, check the fuel pressure, both with the engine running and with the engine off/key on.
With the engine running, you should see 28-30psi, and with the engine NOT running, it should be about 40.
Also, if possible, try to check the pressure when the engine is under load and "cutting out"...
Did you ever change the fuel filter?
