Sponsored by: Auxito
1997 4.6 engine swap...please help
Old May 7, 2007 | 09:21 AM
bmgro3's Avatar
bmgro3
New member here. Just bought a 97 f150 with 420,000 miles on it. Still runs fine, but bearings sound a little loose. I found an engine, trans with transfer case, and rearend locally. All with 70,000 miles. New stuff is from a 99. Is this stuff all direct bolt in, or can someone tell me what I would need to change. I have the 4 wheel shifter on the floor and the new stuff has electronic, so I'm pretty sure I will have to use my old transfer case. ANy help would be appreciated before I buy this new stuff.
Old May 7, 2007 | 09:23 AM
bmgro3's Avatar
bmgro3
By the way, both are 4.6 automatics.
Old May 7, 2007 | 12:58 PM
galaxie641's Avatar
galaxie641
Should be, IF the newer engine had COP's it won't matter because you will use your coil packs and your fuel rail, as long as you do that you should be fine.
Old May 7, 2007 | 01:37 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
why would he need to swap fuel rails?
Old May 7, 2007 | 02:22 PM
bmgro3's Avatar
bmgro3
Are the transmissions any different? Only reason I ask is because I went on Autozone.com and they list a different trans. # for the 97 than the 99. I would really like to use both the engine and trans with 70k.
Old May 7, 2007 | 02:52 PM
BURNSTOUGHFORD
I think the diffence might have been the depth of the oil pan on the 4r70w...i know that there is two of them...
Old May 7, 2007 | 03:45 PM
bmgro3's Avatar
bmgro3
Thanks for your help guys. I will buy the motor and trans. Sounds like they will work out.
