Sponsored by: Auxito
rear brake problems
Old Apr 30, 2007 | 07:13 PM
Green99f150's Avatar
Green99f150
Question rear brake problems
the brakes seam normal but after sitting 15 mim or so the rearbrake locks up the left side and you only can pull foward after a few block the brakes seam normal and you can back up the truck disk brake front and rear and anti-lock brakes it 99 f150 xlt with less than 20,000 miles
Old Apr 30, 2007 | 07:45 PM
barnettdh's Avatar
barnettdh
Check your emergency brakes. They are drum types housed inside the rear rotors.
Old Apr 30, 2007 | 08:48 PM
TJM70's Avatar
TJM70
"99 f-150 with less than 20k miles"
there's your problem..brakes are probably having some siezing issues due to the fact that the truck has probably spent a lot of it's time just sitting. but i'm sorry i don't know what to tell you...good look tho : ).
later
Old Apr 30, 2007 | 09:25 PM
thehawk789's Avatar
thehawk789
sitting=rusty brakes. inspect and see whats going on in there.
Old May 3, 2007 | 03:34 PM
Green99f150
thanks for the imformation so take the brakes apart clean up the rust and they will be go as new
Old May 3, 2007 | 03:53 PM
jimm66's Avatar
jimm66
I had the same problem. The emergency brake shoes were all worn out and broken. Made lots of noise. Had to change out the backs including rotors.
Old May 3, 2007 | 04:53 PM
LastSplash's Avatar
LastSplash
Try backing up and stomping on the e brake. It will adjust the e brake shoes. I normally do it 3 or 4 times to make sure.
Old May 7, 2007 | 04:04 PM
Percys Armory's Avatar
Percys Armory
any updates?
