32 or 33" tires on 92 F150
Hey there guys. I own a 92 F150 I6 5spd.
I am going to be putting a set of 32x11.5x15 or 33x12.5x15's on the truck this week or next. Only thing is the truck is not lifted at all. Yet.
I would like to put the tires for at least a week or two than lift the truck. Can anyone please tell me if I might run into some probelms here? Will be using the stock Ford rims as well. Not sure if the 33x12.5 will be too wide for them.
I dont mind doing some fender work/removal/rolling to make it fit.
Please post back with suggestions or any info.
Thanks a ton guys.
Trevor
Thanks a ton guys.
Trevor
both are too wide for stock 7.5 inch rims the inflation will need to be breought way down for good tread wear. The tire manufactures recomend at least 8" for both of these size tires.
If you are going to lift it any way i would go to 33 they will fit for the short term unless you are rough on it.
jason90f150
06-04-2016 08:45 AM
Sandgnat
11-06-2015 08:59 PM
Jarred Perelli
07-14-2015 10:17 PM
