Set Up Comes With Everything But 4 Pads And 4 Pistons...is There A Specific Piston I Need Or Are They Easily Accessible? 2000 F350 Dually 4wd Cc...fronts Only
The way you are changing everything, you are going to have a new truck pretty soon.
I am a bit confused to what you are actually buying. How are you buying calipers without pistons?
Are you buying reman calipers, or new calipers?
There are only a few decisions to make if you are just replacing stock units for stock units.
Those would be reman, or new, and loaded (with pads, and hardware), semi-loaded, (with hardware, no pads), or unloaded, no pads, no hardware.
Buy a set of loaded units, and all you have to do is install them, and bleed the system. Done in no time.
Things always seem to Bust at the same time...I found a good price on unloaded but need the pistons also as they said they are re-man and dont have piston. Im considering just buying new and loaded
