Speedometer Gear
Old May 8, 2007 | 04:02 PM
WATTSUP!'s Avatar
WATTSUP!
Talking Caps Lock Was On!
Caps lock was on!
Old May 8, 2007 | 04:04 PM
Big John Hance's Avatar
Big John Hance
Caps lock would capitalize every letter, not just the first one in each word.
Old May 8, 2007 | 05:18 PM
WATTSUP!'s Avatar
WATTSUP!
Try It, Though It Maybe Just My Work Computer Doing It. Anyway I Didn't Think We Were On Here For Grammer Lessons! The Topic Was Speedometer Gears!
Old May 8, 2007 | 08:03 PM
Big John Hance
I know the topic. It is easier to read and respond to topics and posts which use proper grammar. I only wanted to know why you do it.
Old May 8, 2007 | 08:08 PM
Franklin2's Avatar
Franklin2
Originally Posted by ri_truck_guy
The simple formula doesn't work because there was also a change in the tire size...the original gearing was based on a stock 235/75/15 tire, which was about 29 inches in diameter. The new tire size is 36 inches. The tire size is another variable.
I thought he wanted the speedo to read the same as it did before the gear change(correct or uncorrect, whatever it was). I didn't know he changed the tires during the gear change too?
Old May 8, 2007 | 09:06 PM
WATTSUP!'s Avatar
WATTSUP!
I did a little more research and found ri_truck to be right with his gear choice. the formula I found was @ this web site http://www.sccoa.com/faq/speedgr.html.
this is the formula the site uses. Speedometer Gear Teeth = (Drive Teeth * Rear End Ratio * 20.2) / Tire. Thanks for all who posted with all of the helpfull info, and thanks to BIG JOHN for todays grammar lesson!
Old May 8, 2007 | 09:09 PM
ri_truck_guy's Avatar
ri_truck_guy
Dave,
From what I could gather there were two tire changes on the truck. In 89, it should have rolled out of the factory on 235/75/15s. Then someone put 30s on it, then he put 36's on it. My understanding from the various posts was that he ran the truck with the 3.08s with both the 30s and 36s, and the speedometer was off to different degrees with both setups. Calculating from the stock setup was only important to figure out the constant.
It went something like:
Stock Tire x Stock Speedometer / New Tire / Old Gears x New Gears = New Speedometer...in this case
28.9 x 18= 520.2/36 = 14.45/3.08= 4.6915 x 4.56 = 21.39
or, the red gear...
Bill
86 F150 4x4 5.0
