Help... if you can.....
Old May 6, 2007 | 05:47 PM
high-tide's Avatar
high-tide
Power everywhere but will not turn over. Codes as po231 and po603. Nothing before. 02 7.3. Any ideas. thanks. I would like to get home tonight......
High-Tide
Old May 6, 2007 | 05:52 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
P0231 Fuel Pump Relay Driver Circuit Failure
You may have triggered the fuel pump inertia cutoff switch. Have you hit anything abruptly recently? Open the passenger door, and look by the lower right corner of the outside of the glove box, on the side there should be a push button switch with a fuel pump inertia label on it. See if that doesnt fix your problem.
Old Aug 22, 2007 | 10:02 PM
santacruzf250's Avatar
santacruzf250
I'm getting the same exact codes! I haven't hit anything at all. I'm still running fine though. The engine just threw the codes. Could it be something else?
Old Aug 22, 2007 | 10:03 PM
Benny2002's Avatar
Benny2002
Can you hear the fuel pump running?
Old Aug 22, 2007 | 11:09 PM
slack's Avatar
slack
I thought his problem was power everywhere but will not crank/turn over?
Old Aug 23, 2007 | 12:04 AM
Tenn01PSD350's Avatar
Tenn01PSD350
That original post was back in May. I would hope it is fixed.
Old Aug 24, 2007 | 10:20 PM
Vader0121's Avatar
Vader0121
poor s.o.b. still stuck on side of road
