Fuel Filler neck restriction
Old 08-13-2007, 09:22 PM
Vader0121's Avatar
Vader0121
Vader0121 is offline
I can't use the larger fuel pump nozzles at truck stops because of a inner ring in the fill neck on my truck. If I snip/cut it out will it cause a problem?
I tried to get the answer through a thread search and failed.
Old 08-13-2007, 09:40 PM
medhvac's Avatar
medhvac
medhvac is offline
i had that same problem and i just use the smaller one !can u do that? as far as cutting it bigger i dont see any harm in that but thats me!
Old 08-13-2007, 09:44 PM
Vader0121's Avatar
Vader0121
Yes I can use the smaller ones but it is nice to have a little space for the trailer so pulling around back would be better. (where the big rigs go to fill but can still pay cash/debit not TCH or Comdata)
Old 08-13-2007, 09:47 PM
medhvac's Avatar
medhvac
medhvac is offline
just make it bigger and see if it works and let us know!heck that could be the (vader mode) lol!
Old 08-13-2007, 09:49 PM
medhvac's Avatar
medhvac
medhvac is offline
mod not mode!lol
Old 08-13-2007, 10:30 PM
empiretc's Avatar
empiretc
empiretc is offline
a lot of people have just cut out the inner piece. most did it when doing the hutch/harpoon mods. I didn't do it at the time, but its easy to pop it out. Then you can use the larger pump spouts.
Old 08-13-2007, 10:37 PM
aklim's Avatar
aklim
aklim is offline
Open your filler door. You will see 3 bolts around your filler cap. Take those 3 8mm bolts out. Take your cap off. Go on the underside and you will see the 2 hoses leading up to that neck secured by worm clamps. Take them out. Now, take the neck out. Hog out the restriction. Clean. Reinstall. That is what I did. I fill up where I can get it. Doesn't change anything for me.
Old 08-13-2007, 10:57 PM
empiretc's Avatar
empiretc
empiretc is offline
That is the long version of what I meant by "pop it out", but I am sure you get the idea. There isn't much to it. Good dart aklim!
Old 08-13-2007, 11:01 PM
aklim's Avatar
aklim
aklim is offline
Thanx. I was half afraid he'd pop it out by whacking it and drop debris in the tank. Then his next thread will be "Plastic and metal bits in tank. What now?". Better safe than sorry. We took one tank out for a friend because of that very reason. I told him to drill it out and he did. Asked him what he did with the debris and he said he flushed it off with brake cleaner. Guess where it went.
Old 08-14-2007, 09:10 PM
Vader0121's Avatar
Vader0121
Smile
Darn now I've got to come up with som other "vader-mod"
Old 08-14-2007, 09:35 PM
NS F250's Avatar
NS F250
NS F250 is offline
I wonder how ford determined when to use the larger filler neck hole (probably not the technical term, but you get the idea). My 02 F250 has the larger hole, but my 03 E350 does not.
Old 08-14-2007, 09:37 PM
John311t's Avatar
John311t
John311t is offline
I shoulda woulda coulda done this, if when I was doing it I was smart enough to think about this. Damn...oh well i fill at the same place all the time unless im traveling so its not that big of deal for me.
Old 08-14-2007, 09:47 PM
poppie's Avatar
poppie
poppie is offline
so does my 02 f350 and i use the semi island.
Old 08-14-2007, 10:04 PM
Vader0121's Avatar
Vader0121
Maybe the trucks that got the small single pane mirrors got the blockage in the filler neck.
Sorry just a little venting.
LARGE TRUCK tiny mirror
Old 08-14-2007, 10:05 PM
aklim's Avatar
aklim
aklim is offline
By the box of parts that they have on that day? IOW, if they open up the box and it is full of big filler necks, the trucks get big necks.
Quick Reply: Fuel Filler neck restriction
