Quad tires
Old May 6, 2007 | 04:33 PM
nymo's Avatar
nymo
Quad tires
I have to replace the front tires on my son's old Polaris (22x8.10). Is the difficulty factor very high or should I save my sanity and some grief and just take them to a tire shop?
Thanks,
Fred
Old May 6, 2007 | 04:41 PM
1970Custom's Avatar
1970Custom
I try to do all my tires b/c I hate waiting on/ paying a shop to do it.
Usually isn't that hard, tough part is the bead breaking I'm lucky enough to have a tractor with a bucket that works great but most people will either use a high lift and the back bumper of a truck, and others use a tire hammer for that.
All in all, if you've got the patience to do it, its not THAT bad.
Old May 6, 2007 | 07:42 PM
lariat97's Avatar
lariat97
I tried to do mine when I bought my blackwater replacements. I ended up taking them to a tire shop. It took them a long time to break the beads on mine.
Old May 6, 2007 | 11:54 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Some are average, but most are a huge PITA to take off. When I replaced the tires on my '02 Honda, I found out that the factory ran a small ammount of glue around the bead before seating them. Tried everything we could think of, but ended up taking them to a tire shop. Even the tire shop could only break 6 of the 8 beads. We ended up cutting the remaining two beads with a drill and a cutting bit.
I just ordered a new set of tires for my 700R. Hopefully they will be easier than my old Honda...
Old May 7, 2007 | 06:58 AM
GlennFordx4's Avatar
GlennFordx4
Yeah there a pain,if you have a tire shop that will do them let them do it and go and have a beer its a lot work getting the bead to break,but if the bead is broke then I would do them myself.I found that aluminum rims are hard because they have sort of a bead lock built in to the rim and if it has bead sealer on it you might have to cut them off.
Old May 7, 2007 | 11:51 AM
Fordzlla's Avatar
Fordzlla
If you do attempt it yourself, measure the inside and the outside of the rims first.
I had a yamaha tri-moto once that had different diameters. The tires would only come off over one side of the rim.
Old May 7, 2007 | 01:41 PM
jake00's Avatar
jake00
cause of the hassle of it, I'd drop em at the tire shop
Old May 7, 2007 | 08:09 PM
nymo's Avatar
nymo
Thanks for the suggestions,
Fred
Old May 8, 2007 | 08:35 AM
cdrmotorsports's Avatar
cdrmotorsports
Just take them to the tire shop. I had two rears mounted for $15 in under 10 minutes.
cyretired2
New Member Introductions
May 4, 2017 10:59 AM
Ford_Six
Dec 9, 2007 06:52 AM
helifixer
34
Jan 6, 2006 01:29 AM
kbcapecod
Aug 12, 2003 01:18 AM
trouble
Mar 1, 2001 07:05 AM
