Steering Play Question....
Old May 6, 2007 | 03:07 PM
dionysius's Avatar
dionysius
Question Steering Play Question....
The, new to me truck, is a 1979 F350 Supercab, 460 cu in, Rear WD, Automatic.
I have found noticeable slop in the Pittman arm to RH Drag Link joint.
To fix this do I have to replace the entire RH Drag Link or is it not possible to replace just the joint part itself?? So far it appears that this is the only loose joint and it is causing some steering wander.
Old May 6, 2007 | 03:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Joint doesn't come apart from drag link (or tie rods). You will have to replace the entire part.
