Neutral safety switch wiring
I have a 93 F350, 7.3, the truck had an E4OD in it, but I was lucky enough to find a donor truck and now it has the ZF5. Just finished the install at about 3am lastnight, but Ive got one problem. The engine wont crank! I assume it is because there is no neutral safety switch hooked up.
Which wires on the wire harness that used to go to the E40D are the nuetral safety switch wires? There are a ton of wires, and I dont really want to use trial and error so I was hoping that someone in FTE land would know which wires need to be tied.
Thanks in advance!
and
If those don't work inline, here are the links:
http://i179.photobucket.com/albums/w...ke/neutral.jpg
and
http://i179.photobucket.com/albums/w...ike/clutch.jpg
Hopefully that's all you need to figure it out.
Mike
