Front coil springs
Old May 6, 2007 | 12:30 PM
76shortbed's Avatar
76shortbed
Front coil springs
Just a quick question.. does anyone know if front coil springs from a 80-96 F150 will fit our year of trucks? Any help appreciated..
-Dan
Old May 6, 2007 | 08:55 PM
rusty7983's Avatar
rusty7983
check at an autoparts store. if your lucky the part #'s are the same if the parts are too. but be careful there are lots of different spring rates. they vary by engine size, automatic or manual, a/c or not and on and on. you can usually spend 100.00 on a good set from the parts stores. if you want a real heavy duty set see if they make a varirate set, as they are real stiff.
Old May 6, 2007 | 11:56 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
I dont think they are the same. I think the distance between the top mount and the mount at the axle are different. Put the two trucks next to eachother and get your tape measure out.
Old May 6, 2007 | 11:59 PM
Matts72's Avatar
Matts72
They aren't the same...
You'll need model specific springs, as pointed out above, they vary by truck style, optional equipment, and engine size.
Old May 7, 2007 | 12:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
Going to a good spring shop and paying a few bucks for their knowledge and expertise is usually a good bargain.
Old May 7, 2007 | 12:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I'd like to help but can't, because friggen Ford removed the comparison spring charts in 1980. In 1979, and back to the 1940's, one can compare spring rates and diameters between models. No More. It's all done now by the door codes or the VIN.
$%^&%()%$ FORD!
Old May 7, 2007 | 12:39 AM
Torque1st's Avatar
Torque1st
Posting Legend
I bet the spring shops still have those charts!
Old May 7, 2007 | 01:02 AM
Alvin in AZ's Avatar
Alvin in AZ
$%^&%()%$ FORD!
Bill, i think we're on the same wave length.
LOL :)
Kind of a love/hate relationship, in my case. :)
But I say screw it anyway :)
...go to the wreckin yard and buy the thickest-wire-springs you can find that will fit your pickup. I took my .001" reading vernier caliper with me. :) Measure yours first. ;)
Ford put two different ones on the ones i've measured, the thicker higher spring rate one went on the passenger side and a slightly thinner lower spring rate one on the driver's side. I'm guessing because the engine & transmission sets just right-of-center. ??
I say screw that too. ;)
I put two of the heaviest I could find on both sides of mine and it sets square as anything! :) Straighter than it ever did and I bought it new. :)
75 F150 360FE T18 a/c PS 133"wb
The rear leaf springs can be re-arched.
BTDT myself, no big deal anyone can do it.
Alvin in AZ
ps- the higher the spring rate, the shorter they are, while loose.
Old May 7, 2007 | 05:22 PM
76shortbed's Avatar
76shortbed
Thanks for the help guys..
-dan
