O-ring, powersteering line
Old May 6, 2007 | 09:30 AM
sandlapper's Avatar
sandlapper
Had a leak last week and I believe I have found it. Is there a white o-ring on the line that goes into the bushing. If so can I get one at NAPA. Part number would help. I looked for springer pups o-ring list but can't find it. There is nothing left of the o-ring. In fact, I thought it was teflon tape at first but it is hard. Stealership replaced the pump about 2.5 yrs. ago.
Old May 6, 2007 | 12:05 PM
clintbonnie's Avatar
clintbonnie
Is this on the power booster end of the high pressure line? I just replaced mine line afew months back and you have to be careful not to over torque the nut.. the fitting will still move even after tightening.. I don't have the torque reading handy but someone here will know.. Don't know the size of the o ring, sorry..
Old May 6, 2007 | 01:28 PM
clintbonnie
Correction to my above post.. "both ends" of the high pressure "line" (not the fittings) should wiggle slightly if installed properly.. The o ring is what seals the oil.. The last guys to install your hose probably over torqued the fittings..
Old May 6, 2007 | 04:31 PM
sandlapper's Avatar
sandlapper
I just replaced the line. Couldn't find an o-ring and can't wait. Thanks for the info. $28.00 and some change. While I had it off I did the foil removal on the intercooler tube.
IDMooseMan
21
Jul 29, 2017 01:32 PM
Nathan Cox
Jul 5, 2016 09:54 AM
genscripter
Jul 31, 2013 03:04 PM
SMarquez
Modular V10 (6.8l)
Jun 22, 2012 07:10 PM
lyonstail
Oct 13, 2008 03:43 PM
