Anyone know where to buy the o-ring for the tranny dipstick tube on a C6?
I had some viton seals in the garage the last time i had a leak, so i did just installed one of those last year. But now it's leaking again, so i figured I needed a real seal. the PO just used permatex when I bought it, and that didn't work so I didn't have an original o-ring to compare it against.
The hill idea is smart just in case it's up to the level of the o-ring. I put in a universal drain plug in my tranny pan last time i did a tranny fluid change and filter change. And yeah, the van tranny access is amazing. John is right, it's easily accessible once you have the doghouse cover off, and/or from under side. the hardest part about it is lining it up, so if you have a helper, (one guy on the inside of the van, lining up and bolting down the tube, and the other guy on the underside, sliding on the o-ring and seating the tube in the tranny) that's the best possible scenario. but you can do it all by yourself too.
Brnfree
11-17-2014 11:25 PM
bowdog
06-16-2008 02:43 PM
beeboy
04-04-2004 11:18 AM
