Should the driveline be offset?
Old May 6, 2007 | 12:30 AM
hoxiii's Avatar
hoxiii
Allright, quick question.
1985 F-150 4x2, 300-6, NP 435.
Should the driveline be centered under the body or does the motor/transmission sit offset about 1" to the drivers side?
Justin
Old May 6, 2007 | 08:55 AM
fellro86's Avatar
fellro86
Actually, the motor/trans and driveline sit offset to the passenger side... not centered in the frame.
Old May 6, 2007 | 12:51 PM
hoxiii's Avatar
hoxiii
hmm. . . that's weird. I'm messing with a truck and the whole driveline sits to the drivers side by 1". I recalled the driveline being offset, but couldn't recall what direction it was.
Guess i need to figure out what's causing the twist.
Justin
Old May 6, 2007 | 01:43 PM
fellro86's Avatar
fellro86
Are you talking about in the frame drop, or in relation to the center of the fenders? The whole driveline is 4" to the passenger side in relation to the fenders center, but should largely be centered in the drop of the frame.
Old May 6, 2007 | 03:38 PM
hoxiii's Avatar
hoxiii
within the drop it sits 1" to the drivers side. It can be noticed most from inside the truck with the tunnel cover removed.
The transmission angles front drivers side at the front to passengers at the rear and the motor sits with the bellhousing centered but the front pointing to the drivers side. the whole thing is twisted around the bellhousing.
Justin
Old May 6, 2007 | 06:03 PM
fellro86's Avatar
fellro86
Somehow it definitely has shifted around.Have you checked the integrity of the trans mount?
Old May 6, 2007 | 07:19 PM
Franken-Truck's Avatar
Franken-Truck
is it possible someone put the tranny crossmember in backwards? Or used incorrect/backwards engine mounts/towers?
Or, worse case, was it previously wrecked and has a bent frame?
Old May 6, 2007 | 08:45 PM
hoxiii's Avatar
hoxiii
haven't gotten a chance to get up under there yet, but i have a pretty good feeling it's the trans mount. I've never liked the 4x2 ones from this era, they tweak way too easily.
I'll let you know how it turns out, but i honestly don't know the next time I'm going to be able to get out to mess with it, this week is gonna be craazzyy.
Justin
