Whiter Whites Help
Old May 5, 2007 | 11:51 PM
eman resu's Avatar
eman resu
Post Whiter Whites Help
I'm doing the "Whiter Whites" conversion on my 1985 F-150 and electrical isn't my strong suit. I'm having a problem finding the correct wire to connect the fuses to. I'm looking for the wire that the diagram shows coming from the headlight switch to the battery. I think the correct wire at the switch is the Black/Orange wire. I do see a Black/Orange wire connected to the starter relay, but it seems to go to the alternator. Is this the correct wire? If not, any help you can give me would be greatly appreciated. If it is, I'll just splice in the fuses. Thanks for your help.
Old May 6, 2007 | 11:48 AM
Mil1ion's Avatar
Mil1ion
That power wire to the headlight switch has to stay as is.
It is the Headlight switch to headlight wires that have to be re-directed to the New Relay Box holding the relays.
You need a New larger gauge wire from the battery to the relays..from the relays to the headlight.
See this schematic..it shows it better.
http://www.northwestvintagebroncos.c...headlight1.htm
