Thump on acceleration
Old May 5, 2007 | 09:20 PM
guitarpicr's Avatar
guitarpicr
Wink Thump on acceleration
My new to me 2002 F-250 Lariet ex.cab,sb, psd, 2wd, automatic tows great and runs great but I am feeling a slight bump or thump when I leave a stop light. Its more noticable when Im not towing. Almost feels like a brake caliper sticking as I had this happen on an old truck I had years ago. Just was looking for any input from other psd owners out there. Thanks in advance for any help! By the way truck has 76,000 miles , and has had new brakes within the past 10,000 miles.
Old May 5, 2007 | 09:41 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Is it a thump or could it be a clunk? There have been many cases of driveline clunk here. Could it be the driveshaft clunking? Are you able to narrow down the source any?
Old May 5, 2007 | 11:12 PM
mjlewis's Avatar
mjlewis
i'm curious about this thread... my 02 does the same thing, almost like there's something out of alignment at take off. could the slip joint need re-greasing?
thanks
-mike
Old May 6, 2007 | 12:05 AM
1996pwrstrk's Avatar
1996pwrstrk
Thats what it sound's like to me.
Old May 6, 2007 | 05:12 AM
dsldandually's Avatar
dsldandually
yeap sounds like the dreaded slip yoke clunk......easy fix is to drill the slip yoke and install a zerk (grease) fitting. every oil change give it one pump with the grease gun
Old May 6, 2007 | 10:04 AM
mjlewis's Avatar
mjlewis
Eurekaboy has an outstanding webpage on how to remove and re-grease the slip joint. looks like a very easy job.
http://www.eurekaboy.com/f250/slipjoint.htm
Old May 6, 2007 | 11:45 PM
guitarpicr's Avatar
guitarpicr
Thanks for all the help. I'll give this a shot tomorrow. By the way this a great forum. I learn more reading here than any books can teach. Appreaciate the input.
Old May 7, 2007 | 01:02 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
I found this place after I bought a repair manual that stated "Due to the complexities of the diesel engine we wont get into it very far." I started reading here that day and have never looked back. FTE is quite the site with some of the most helpful people I have ever met. Your in the right place!
Old May 7, 2007 | 09:27 AM
F250_'s Avatar
F250_
Great long term fix concept! Can you provide more details, perhaps a few pics for where to best install the fitting?
Old May 7, 2007 | 03:30 PM
John311t's Avatar
John311t
One year ago, i didnt know crap about this motor. I was brought up around gasoline motors my whole life. Now i know more about oil burners than any gasser lol.
Old May 7, 2007 | 05:47 PM
empiretc's Avatar
empiretc
i had the same problem and it was the u-joints. When I took the drive line down, I replaced the u-joints and carrier bearing and greased the slip yolk. While I was at it, I shimmed the carrier bearing as well. Every now and then it will start to do it again, but once I grease the u-joints, it goes away.
I never did get the drive line balanced, but that would be the last resort. Next time I take it down, I will put a zerk to grease the slip yolk.
Old May 7, 2007 | 05:56 PM
rbaker6336's Avatar
rbaker6336
seems these trucks are famous for slip yoke clunk
ford sells a special grease to lube them with but would most likely be better to drill and tap yoke and grease with a good high impact grease
on class8 trucks everythng is bigger but same andthats the way we greased the for years and never had a problem if the were greased properly
Old May 27, 2007 | 04:57 PM
guitarpicr's Avatar
guitarpicr
Well i finally got time to pull the driveline and grease the spline and this took care of the clunk. I thought about drill and tap but was worried about this throwing the weight off. I dont know if this would throw it out of balance. Any thoughts? Thanks to all for the help.
