Negative front wheel camber. What to replace?
I work with heavy equipment as well, and right now am doing commercial construction. I do all the repairs and maintenance on our equipment, as well as operate it.
Just purchased a black 87 325is, missing
air dam and fog lights have the mounting brackets.
The "IS" series dam is too low I like the standard ones plus
standard is more common.
Looking for a black standard 325 series not "es or "is" dam,
fog lights and brackets if brackets are different than on
"es" or "is" series. Want without damage or cracks, anything at your end?
I'm left coast S.F. bay area. PM is ok.
Back to topic before Dan comes down my way and thumps me on the head.
It's 80 F and windy Dan today.
You being in heavy equipment with mechanical ability you would
know or learn more than many repair shops on replacing king pins
and bushings. The reamer is the big ticket item especially a specical
reamer with pilot to ream correctly. Best of luck and keep that great
looking truck away from salt.
The bMW e30 front steel valance and plastic air dams changed over the years. It is a little confusing.
Pre-7/88 (big bumpers) "iS" and "eS" only had 1 front air dam and they are identical.
http://www.astheroundelturns.com/gal.../my_84_318.jpg
I don't have any as I put the last one I had on my Red '89 325i (small bumper).
http://www.astheroundelturns.com/gal..._001.sized.jpg
I don't know what this "standard spoiler" thing is you're talking about?
The NON "s" "spoiler" on a pre-7/88 is actually a steel valance with plastic lower lip .
http://www.astheroundelturns.com/gal...orclient1b.jpg
In '88, right before the small bumpers came in ...the post 7/88 steel valance (with foglights incorporated into them) came on a few of the last big bumpered cars like this '88 325 (super ETA).
http://www.astheroundelturns.com/gal..._sale_014b.jpg
Then the small bumpers (post 7/'88) with the newer valance was standard on all "s" and non "s".
http://www.vwgolf-mk2.com/owners/onosan/onosan3/003.jpg
The post 7/88 "s" may have had a lower add-on.
http://www.bmwpugetsound.com/member_...0_325is_02.jpg
(Probably my own fault for bringing it up in the first place...
)Jon, I changed your pics into links so the rest of us don't have to have our eyeballs assaulted by all that German steel.
(Not that I'm one to talk with a Mercedes 280E sitting on the trailer in the driveway right now that I just dragged home...
You take it to an alignment shop that does mostly cars and all they will do is set the toe in - they do not have the jacks to bend the axle.
If you need springs repair or replace them before you go to the front end shop. I build up my own leaf springs normally from several used packs but sometimes it is easier and even cheaper to go to a spring shop.
I had to find some bushings I had ordered from one of those vintage catalogs, when they sent the wrong ones on my '59. The local spring shop had them in stock for less money. In fact, they offered all the parts and to do all the work, including installing the king pins, for less money than I had spent on vintage parts.
I had already installed the king pins (reamed them out myself), but the next time . . .
Therefore I called Green Sales (in Ohio) and they were very helpful.
They have the parts in stock at a very reasonable price. (I hope they are a sponsor here as this might be construed a "plug").
I mentioned FTE...and I think that helped?
Anyhow...I will proceed with the king pin/bushing replacement first.
I will take measurements before and after the repair to see if the repair was significant.
Then...(if required) I will proceed with some Yankee Ingenuity :
If worst comes to worst, I can always flip-flop the rubber on the rims so they wear evenly(i have a tire machine and have done huge loader tires myself/ I have used a com-a-long to lift the rim/rubber up-over & onto the machine). The truck does not get any long distance driving anywho. I have put maybe 500 miles on it in 5 years.
