Replacing Rag Joint 78 4x4
I have never done a 1978, if it is like the older or new ones, you take off two nuts holding the steering column for some play room, go under the hood and remove two 1/4" bolts holding each side of the UJ to the steering shaft, slide the new one on over the splines. Note, some steering set ups only have one bolt. Then reverse.
Spraying some PB Blaster down the splines might not hurt.
stercorarius
03-14-2015 11:15 PM
1983F1503004x4
03-05-2013 11:57 AM
jimmyhighrider
19
04-29-2012 02:26 PM
