74 F100 Fueling Problem
Old May 4, 2007 | 08:31 PM
cuffemdude's Avatar
cuffemdude
Question 74 F100 Fueling Problem
I just purchased an 1974 F100. I'm having problems getting gas into the truck without it spilling all over the place from the tank opening. The only remedy I've found is to barely squeeze the trigger on the fuel pump nozzle. It takes me about 9 minutes to completely fill the tank as I have to pump it so slowly. If anyone else is familiar with this problem, and a remedy, please respond.
Old May 4, 2007 | 08:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check for a pinched or partially collapsed hose from the fill neck to the tank. Replace the hose and fix whatever is pinching it.
Old May 4, 2007 | 10:24 PM
rusty7983's Avatar
rusty7983
i had that problem with a ranger i still have. like torque said, i had the filler line twisted just a bit. it was tough to see. it was a pain in the a** to fill. it got me pissed, i fixed it.
Old May 5, 2007 | 01:09 AM
75 SuperCab's Avatar
75 SuperCab
This is a very common problem on the older trucks with the external gas caps. Although it's been discussed many times on this website. I've yet to find anyone who has come up with a reasonable modification to solve this problem.
So at this point, all I can tell you is that the cheapest & easiest way to avoid this problem is to carry a 2-foot length of cut off garden hose with you and slip one end of it over the gas nozzle and stick the other end into your gas tank whenever you are refueling your truck. You would also be well advised to avoid stations that use the compresseion style of nozzles for vapor recovery as they are not very user friendly to those of us who would rather not smell like they have used gasoline as an after shave!
LB a.k.a. 75 SuperCab
Old May 5, 2007 | 01:11 AM
Alvin in AZ's Avatar
Alvin in AZ
On my 75 F150 only the rear tank was a problem and still isn't all that good. :/
I bought Ford replacement fuel hoses for the rear tank and they had "top" and "toward tank" stamped on them with arrows. When I took the originals off, turned out they had been put on there upside down and backwards at the factory. (i bought the pickup new)
There's a metal bracket that the hoses are supported by... IMO it's too low, it was straight down like an L and I bent it like a Z. Or did I go the other way? :) Opening the Z Or L) Like \_ ? Either way it raised the hose going into the rear tank.
That and wrapped the new large hose with a tin can and hose clamps which made the hose rounder and the tin can protects the hose from abrasion from the frame and bed's "seam lip". Rounder made the hose's "bottom" lower.
But more than anything i believe what will do you the most good is finding gas pumps where the pickup can lean toward the passenger side -and- have the gas pump nozzles that have the bend in the center of the pipe.
I took the bed off my pickup and worked over the tank situation even. And I can still have quite a bit of trouble... if the pickup's leaning even-just-a-little toward the drivers side even with the good-bent-type filler nozzle pipe.
Whatever you figure out, good or bad, get back to this thread and tell us about it. :) Ok? :)
Alvin in AZ
