cab mount bushings - help, please
Old May 4, 2007 | 07:23 PM
TN_Explorer's Avatar
TN_Explorer
OK, so it's 2 years later. I have a completely new floorboard welded into the cab of my '70 F-100, and new urethane bushings. I hunted all over for the bolts & finally realized I had torched them off, along with the rubber mount biscuits. I just got a new mount kit from Blue Oval, and I don't know which ones go where. I couldn't find just the bolts, & so had to buy a complete set with the rubber bushings. Now the questions:
There are two sets of large diameter biscuits. One is fluted with holes in it, the other is plain. Which is front & which is rear?
There are two sets of small diameter biscuits. One set is taller & larger diameter. Front or rear?
And is this the proper order (from the top)?
1. bolt
2. small washer
3. large washer
4. cab
5. big donut
6. frame
7. small donut
8. big washer
9. small washer
10. nut
Thanks in advance from you guys who have blazed the trail before me!
-- Mike in Tennessee
Old May 4, 2007 | 07:33 PM
BobbyFord's Avatar
BobbyFord
The ribbed insulators are for the rear (between cab and frame), the smooth for the front (between cab and frame). The taller of the smaller diameter goes to the rear cab mount.
You have the correct 1-10 order.
Old May 5, 2007 | 06:10 AM
TN_Explorer
Smile
THANKS, INSTIG8TR63!!! Much appreciated
Luke76
May 11, 2018 08:04 PM
Speedjester
Jul 23, 2015 03:06 PM
Tedybear
Jun 20, 2008 07:26 PM
JTD1972
1978 - 1996 Big Bronco
Feb 12, 2004 05:41 AM
Blaine
13
Feb 9, 2003 01:32 PM
