axle id help please
Old May 4, 2007 | 05:35 PM
spazinweasel's Avatar
spazinweasel
axle id help please
hello new here but not to fords i need some help on axle ids please front is a 3.54 e6ta pa 610255-1 one rear is v126a 3.55 10 25m20 other rear is a drw 3.54 e5ta ala 80525041 thank you for any and all help and the drw im looking at puting in a 85 f350 w/ a 351w c6 and it already has a dually bed on it any other info would be great thank you all!!
Old May 4, 2007 | 06:06 PM
andym's Avatar
andym
610255-1 is a Dana BOM number. It decodes to:
FORD Model 60 FRONT 1986 - 1988 F-350 MONOBEAM DRW (3.54)
The one that starts with 3.55 is a Ford axle tag. It's a sterling (visteon) 10.25" axle with a 3.55 ratio, open carrier.
The third number I don't recognize.
But if it's under an 85 F350 dually, then it's most likely a Dana 70 or so - maybe an 80.
Old May 4, 2007 | 06:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
E5TA-ALA = Dana 70 non locking / 3.54-1 Axle Ratio
1980/89 Ford Light Truck Parts Catalog / Section 40; Parts List #176
Old May 4, 2007 | 06:17 PM
spazinweasel
the drw axle has a 70hd on the webbing if that helps at all thank you for your help andym
Old May 4, 2007 | 06:19 PM
spazinweasel
thank you numberdummy
