engine miss when cold?
Old May 4, 2007 | 04:31 PM
8tsixt's Avatar
8tsixt
Hello all! i am new to this site and learning alot. i have a 2000 f350 dually with 306,000miles. when it is cold it feels like it has a miss or cylinder missing, once it is warmed up it is okay. has anyone experienced this or something similar? i already tried an oil change, fuel filter, and fresh diesel. it has a towing chip and thats about it for mods. i live is so. cali so the temp is not even that cold here. any help would be nice. Thanks to all.
Old May 4, 2007 | 09:08 PM
8tsixt's Avatar
8tsixt
i also replaced all the glow plugs on the drivers side due to one showing 3.5ohms.
Old May 4, 2007 | 09:14 PM
medhvac's Avatar
medhvac
is it a miss are is it bogging down when you depress the pedal?
Old May 4, 2007 | 09:22 PM
pullinair's Avatar
pullinair
http://video.FTEs diesel forums.com/search/6.0+bdp+turbo/0/badcfe55-ae7e-4755-a489-f43bb0950534.htm
Sorry Cant stop wathcing that one!
or this - For real hear is a missing truck
http://video.FTEs diesel forums.com/...95010b6ba3.htm
Start thinking about foing a Cylinder Conytibution test if its rattlin like the video in the mornings. It will detect a bad injector. Are you still on original injectors?
Old May 4, 2007 | 09:29 PM
medhvac's Avatar
medhvac
either im deaf or crazy man i didnt hear the miss in that video!and yep i like that 6.0 one!
Old May 4, 2007 | 09:34 PM
pullinair's Avatar
pullinair
Theres a prominent tick there. Gotta turn the Metalica down to hear it!
Old May 4, 2007 | 09:39 PM
medhvac's Avatar
medhvac
i hear ya but my truck makes so much noise if i had a miss i would never hear it! unless the truck shook!
Old May 4, 2007 | 10:40 PM
8tsixt's Avatar
8tsixt
mine sounds sort of like that but with no tick. as soon as it gets hot it goes away completely and drives normal. when i try to drive it will feel like there is a cylinder missing. i can let it sit and start it up warm and it will run perfect.?? as far as the injectors go, i dont know if they have been replaced since i bought it recently.
Old Jun 11, 2007 | 09:38 PM
whybnormal's Avatar
whybnormal
8tsixt, not trying to hi-jack your thread, but I am having the same problem in my early 99 with 116,000 miles and wondered if you figured out your problem. Sometimes when I first start it and drive it feels like a dead miss. I did a cylinder contribution test once while it was missing and it showed cylinder 4. The miss goes away once I let the truck warm up and shut it off and restart it or sometimes when I go drive it and floor it for a second, it clears up. Any suggestions? Once the miss goes away, it stays away until the truck sets for a couple of days again.
Old Jun 11, 2007 | 09:55 PM
8tsixt's Avatar
8tsixt
No worries, I am still working on trying to get a reman set of injectors to replace all 8. I took it to the dealership and was advised to replace all 8 because of miles. I wouldnt doubt you have the same problem. Good luck to you.
Old Jun 11, 2007 | 10:04 PM
whybnormal's Avatar
whybnormal
Thanks, keep me posted. I found a place that sells an injector rebuild kit. Could that be a reliable option?
Old Jun 11, 2007 | 11:08 PM
8tsixt's Avatar
8tsixt
I might try it myself.
