mickey thompson
Old May 3, 2007 | 10:16 PM
01redcrew's Avatar
01redcrew
mickey thompson
has anyone ran the baja radial mtx or the baja radial atz how are these tires in wet,mud,n snow and how long do they last .
thanks alot for any feedbacl
Old May 3, 2007 | 10:20 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If you are looking at the MTZs, i would seriously look at toyo's Open Country MT. I have worked several times on a truck lifted with 37" MTZs, and those tires hum, loud. And starting off or making a slow turn, you can feel each lug contact the ground and make the truck shake. The guys running toyo's are loving them, im going to 33" toyo MT's when i fit the wheels and tires into the PMS budget. The MTZ's don't wear too well from what several owners ive talked to say.
Old May 3, 2007 | 10:26 PM
yamaguy's Avatar
yamaguy
I ran the mtx radials on my 96' once. They were a great looking tire, but the performed like racing slicks in the mud and snow. I do not recommend them. You should look at the BFG AT's they are the best tire I have ever run. You pay a little more for them, but imho they are worth every penny!!!! I have run them through 16" of snow with drifts a little deeper in 2wd and could not get stuck!! They would just dig and then throw you about 10 or 20 feet and then you would lose momentum and just start digging again. I usually get 70 to 80,000 Mi out of them as well. Plus you can get them in E rating in alot of big sizes.
Old May 3, 2007 | 10:27 PM
yellow401's Avatar
yellow401
I don't recommend the Baja Claw radials...wear too quick, are terrible in the snow, hard to balance 37's
Old May 3, 2007 | 10:33 PM
Benny2002's Avatar
Benny2002
I can give the big thumb on Toyos MTs wont go with another tire again, there a little spendy but worth it
Old May 3, 2007 | 10:35 PM
01redcrew's Avatar
01redcrew
sry but a buddy has bfg 285 n i hate them, but they are a great lookin tire tho
Old May 4, 2007 | 09:49 AM
BoostRetard's Avatar
BoostRetard
Talking
Mine look great in my shed, I'll let you know once they are on.
Old May 4, 2007 | 01:02 PM
01redcrew's Avatar
01redcrew
which tire is that
Old May 5, 2007 | 06:01 PM
mann56's Avatar
mann56
will 2005 superduty 3/4 ton wheels fit on a 2000 superduty?
Old May 13, 2007 | 12:52 AM
BoostRetard
I have the mtz's.
Old May 13, 2007 | 07:22 AM
jrciii56's Avatar
jrciii56
I am currently runnng 35" toyo AT's and I love um. Little if any road noise. Ride is very smooth. I haven't had them in the snow or mud yet so I cant comment on that.
Old May 13, 2007 | 11:01 AM
PowerstrokeJunkie
Mann56, no they will not, the bolt pattern is different along with the backspacing.
Jamie, how did the lift install go, and how is it doing?
Old May 13, 2007 | 03:15 PM
DCSpecial's Avatar
DCSpecial
Actually no, the 05-07 SRW trucks and 99-04 SRW trucks both use the 8x170mm bolt pattern.
Issue is the backspacing....99-04s is ~4.5", while the 05-07 is ~6"........so a 05-07 SRW wheel will bolt onto a 99-04 SRW truck, but they will be tucked under the truck a decent amount and most likely will rub on the leaf springs.
Old May 13, 2007 | 05:14 PM
SBChero's Avatar
SBChero
i run the mtx (LT315/75R16) i think theyre great. they work great in the dirt and sand. aired down i have pulled out a drw dodge 3500 w/ a 35' travel trailer out of soft sand.
cant comment on the mud though, havent had it through any yet.
ive got about 10k on mine and they still look new. id say about 90% left.
they ride great and have no more noise than a regular tire of the same tread.
