Another Gasser Gone!
Old May 3, 2007 | 08:54 PM
Winger235's Avatar
Winger235
Thumbs up Another Gasser Gone!
Been hard at work converting another Gas Pig to a Diesel. Hopefully will be running around in the new conversion by Sunday. Used to be a 1989 F-350 4x4 460 C6 3.55's. Soon to be a 1989 F-350 7.3L E4OD 3.55's. This one is turning out nice not many issues just shortening the rear drive shaft because of the longer drive train. This will be the warm up for the 1971 slated for Mid-June. If I have my brain with me tomorrow pictures will be forth coming. Should be around 10 days start to finish.
Old May 4, 2007 | 05:50 PM
Winger235's Avatar
Winger235
No Brain today but she is almost buttoned up bringing camera tomorrow for sure.
Old May 5, 2007 | 12:34 PM
faststang94's Avatar
faststang94
is that a direct bolt in ?
Old May 9, 2007 | 08:53 PM
Winger235's Avatar
Winger235
All done truck runs and drives nice. Really only had to change engine mounts and transmission cross member Shorten the rear drive shaft. The donor truck had the front drive shaft already. Wiring harness was the same inside cab just needed to change transmission module and engine compartment wiring harness. New fuel and trans lines 100 gallon fuel tank. I can't find my cable for the camera to transfer the pics but will look tomorrow.
1989_f250
Jan 9, 2013 05:35 AM
MKEBoost
2009 - 2014 F150
19
May 16, 2012 09:11 PM
usmc0602
May 18, 2009 01:23 AM
KeithMS
Jan 27, 2006 02:31 PM
w9jcm
Dec 17, 2005 02:47 PM
