Hey, on my 00 7.3 about 2000 miles after I changed the oil it developed a leak. It appeared to be coming from the Vally below the turbo but when I pulled the dipstick it was way overfull. I drained and refilled oil to the proper level, 300 miles later it's over full again, what could it bed?
When u change your oil how much are you putting in?
when i just changed it, i just pulled the plug and drained it, pulled the filter installed a new one between filling the filter and filling the pan i used 12 quarts.
00 7.3. i just had it in the garage to start looking for were the oil was leaking from. below the oil filter there is a big snap ring aiming towards the turbo, the oil is leaking from that area. i wiped it down and started it and saw it drip a couple time. could there be a internal problem there?
yea, its leaking right around that snap ring or out of the bottom of the HPOP. i haven't been driving it since i noticed it was making oil, could the hpop be junk?
No, my leak doesn't sound as bad as yours. After 1,000 miles my truck only made a little oil on the dipstick (I had 5.9% Fuel in my oil sample, which was like $30.00) I would imagine that you have more...it takes a couple of days for the results but worth knowing because injectors are expensive
