General Automotive Discussion
Air consumption?
Old May 15, 2007 | 06:07 PM
Beerstalker's Avatar
Beerstalker
We need the approximate dimensions of the tank so we can figure out the surface area.
Old May 15, 2007 | 09:49 PM
riggz's Avatar
riggz
It's a 5 gallon tank from siege engineering on ebay. According to the description it's 11" x 11" x 21". How do the dimensions factor in? I thought a 5 gal is 5 gal regardless of shape.
Old May 15, 2007 | 10:47 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
An air horn is an air horn. They'll work down to about 65 or 70 psi. But, the more air you got, the louder they are. The way a rig works is the compressor cuts out at 120 psi, cuts back in at 80 psi. Then there's a high pressure relief at 150 psi so the tank is safe. Horns are air hogs though, if you ever hear a truck laying on it's horns, it's for a good reason (getting cut off). Otherwise, they usually only "toot" them for backing up, or saying hello.
If I were to put money on your setup, I'd say you'd run out of air in about 7 seconds.
Old May 15, 2007 | 10:57 PM
riggz's Avatar
riggz
in my line of work we use them to clear the roads. our engines have air brakes so it's a lot larger systems. our rescue's w/o air brakes also have air horns, but i haven't checked what size tanks/compressors they have. i do know they last longer than 7 seconds.
Old May 16, 2007 | 12:20 PM
riggz's Avatar
riggz
So the volume of the 5gal tank is roughly .77 cu. ft.
The engineering problem:
What size tank will it take to run 2 horns operating at 7cfm & 110psi via a regulator with the initial tank pressure at 150psi for 15 seconds. Output pressure can not drop below 110psi.
Old May 16, 2007 | 12:55 PM
riggz's Avatar
riggz
Here's what I've come up with using Boyle's law.
Code:
pa Va = pc Vc (1) where pa = atmospheric pressure (14.7 psi, 101.325 kPa) Va = volume of the gas at atmospheric pressure (cubic feet, cubic meter) pc = compressed pressure (psi, kPa) Vc = volume of the gas at compressed pressure (cubic feet, cubic meter)
5gal tank = .77 cuft
.77 cuft tank @ 150psi = 8.6 cuft
.77 cuft tank @ 110psi = 6.5 cuft
8.6 cuft - 6.5 cuft = 2.1 cuft
7cfm x 2 = 14cfm = .233 cuft/sec
2.1 cuft / .233 cuft/sec = 9 seconds
8.5gal tank = 1.32 cuft
1.32 cuft tank @ 150psi = 14.8 cuft
1.32 cuft tank @ 110psi = 11.2 cuft
14.8 cuft - 11.2 cuft = 3.6 cuft
3.6 cuft / .233 cuft/sec = 15.4 seconds
Any thoughts?
marshallstanford
Jul 15, 2016 06:42 AM
jdadamsjr
All Things Towing
Nov 26, 2014 04:17 PM
porthole
6.7L Power Stroke Diesel
Jul 30, 2011 08:36 AM
Duke78
Paint & Bodywork
Nov 24, 2007 02:45 PM
fmc400
Electrical Systems/Wiring
Oct 6, 2006 10:22 PM
