big white/blue clouds
Old May 2, 2007 | 11:05 PM
bigbadwolfe's Avatar
bigbadwolfe
Unhappy big white/blue clouds
my truck looks like a crop duster right now when i hit the pedal it is killing me right now its a powersmoker pleas help it smells like oil o rings maybe
Old May 3, 2007 | 03:11 PM
Cuda_jim's Avatar
Cuda_jim
It could be injector orings or injector sleeves.
Is it missing?
Does it smoke all the time or just cold?
Does it start good from dead cold?
Remove the oil fill cap on the valve cover. Look for steam or a mist coming out while the engine is running. Let us know what you see. Blowby?
Old May 3, 2007 | 03:16 PM
powerstroked162's Avatar
powerstroked162
Could he be leaking coolanat at the heads perhaps?
Cowboy Steve
Old May 3, 2007 | 03:31 PM
Cuda_jim's Avatar
Cuda_jim
I suspect he would've said it smelled like coolant not oil. IDK tho.
Old May 3, 2007 | 03:34 PM
powerstroked162
Very good possibility. Blowby is a very *****ty deal!
Cowboy Steve
Old May 3, 2007 | 06:02 PM
Tofudi's Avatar
Tofudi
My goal here was to capture a black smoke ring on film. All I accomplished was a smoke screen over my entire neighborhood.
Originally Posted by powerstroked162
You'll be lucky if Cookie lets that pic stay on the thread. Attatchments only brother.
Cowboy Steve
Thanks. I didn't know. Fixed it.
Old May 3, 2007 | 06:10 PM
powerstroked162
Cowboy Steve
Old May 3, 2007 | 07:30 PM
bigbadwolfe
well i ordered diy stage one kit i would just like to know if someone has a good write up on removal
Old May 3, 2007 | 07:35 PM
powerstroked162
Stage 1 kit for what?
Cowboy Steve
Old May 3, 2007 | 07:46 PM
bigbadwolfe
injectors what else
Old May 3, 2007 | 07:50 PM
powerstroked162
Well i thought we were talkin about your truck smokin like a crop duster. Probably ought to get that issue fixed first before you start dumpin more fuel in it, just my $.02 worth
Cowboy Steve
Old May 3, 2007 | 08:31 PM
bigbadwolfe
well i think its the orings on the injectors so while i am in there may as well get down and dirty and do it right it makes no sence to do it twice and i realy want them i got PMS
Old May 3, 2007 | 08:44 PM
powerstroked162
To the un-trained eye, they might think you had a problem. lol, makes most sense to do it all while in there. I think Tj has a pretty good write up on the install, if not Rubberduck has a good one. Good luck
Cowboy Steve
