1978 - 1996 Big Bronco
Code Readers Needed
Old Apr 28, 2001 | 10:32 PM
jkt's Avatar
jkt
Code Readers Needed
I have a 1979 Ford Bronco and the tag that is bolted to the 9" third member reads:
WEE-AZ 9DE
4L11 9 626D
What does This mean?
Old Apr 28, 2001 | 11:12 PM
hotrodford_88's Avatar
hotrodford_88
Code Readers Needed
[font size="1" color="#FF0000"]LAST EDITED ON 29-Apr-01 AT 00:12 AM (EST)[/font][p]>WEE-AZ 9DE
>4L11 9 626D
Well from what I can come up through the obvious, is a 4.11 with a locking differential. But that's as far as my knowledge goes.
I figured that's what you were looking for anyway.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Apr 28, 2001 | 11:38 PM
jkt's Avatar
jkt
Code Readers Needed
That was what I thought, just wanted to make sure that I order the right gears.
Thank You
Old Apr 28, 2001 | 11:48 PM
hotrodford_88
Code Readers Needed
Also, count the number of teeth on the ring gear, and the pinion gear, and divide the ring gear by the pinion gear. That'll also give you you're ratio.
Can see both below.
Old Apr 29, 2001 | 07:48 AM
fatforty's Avatar
fatforty
Code Readers Needed
robert_l_ross
Jun 20, 2024 10:16 AM
boss429
Jul 19, 2011 11:43 PM
mshumack
Aug 19, 2002 08:36 PM
rusty9
May 26, 2002 11:05 AM
